Old 11-02-2015, 07:23 PM   #1
72tutone
Valve train gurus needed
I'm rebuilding my .060 350 and am at the point of zero lashing my valves. This is on a hydraulic flat cam. If u look at the pic the witness mark appears to be outboard or the valve stem. Should I get some that are .050 shorter? I'm running 7.794 now
72tutone is offline   Reply With Quote
Old 11-02-2015, 09:06 PM   #2
GRX
GRX's Avatar
Re: Valve train gurus needed
My vote is yes. I would go with 8.050. This is where an adjustable pushrod length checker is useful. I have one from Crane Cams. Every full revolution of threads = .050" .
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 11-02-2015, 09:28 PM   #3
72tutone
Wouldn't a longer pushrod move me more toward the exhaust side? I'm thinking ithe mark needs to move more toward the litter valley which means a shorter rod. Correct?
Old 11-02-2015, 09:44 PM   #4
cableguy0
Your correct. However as mentioned without a pushrod length checker this can become a very expensive guessing game.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-02-2015, 09:54 PM   #5
72tutone
This is true. What about. Measuring the width of the mark with dial calipers and adding .050 up the valve stem? Or .100
Would this work?
Old 11-02-2015, 10:01 PM   #6
picklito
Don't lose track of that set screw!
picklito is offline   Reply With Quote
Old 11-03-2015, 10:59 AM   #7
72tutone
Hmm, I just thought of something.
When doing this, I am zero lashing the valve but I'm also preloading the lifter 1/4 turn. I would assume when doing this, I would be adjusting the valves as I would the final time.
I just want to make sure that this is correct. I hear some people are just zero lashing the valves and "NOT" preloading the lifter when doing this.
Which way is correct?
Old 11-03-2015, 08:57 PM   #8
cadillac_al
They should have at least a 1/4 turn to keep everything quiet.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 11-03-2015, 09:10 PM   #9
cableguy0
You should be using a solid lifter to check pushrod length. You will get weird readings with hydraulic lifters because the spring will collapse the lifter due to lack of oil pressure to pump up the lifter.
Old 11-04-2015, 12:59 AM   #10
crazy longhorn
Fabricate till you "puke"
It sure looks like the pushrod is too long....Listen to what Cable has to say I check mine differently (light checker springs), & use the hyd lifter. Tit for tat, no difference? You can also get the pushrod "checker"....drop that plastic , un moveable rocker on top @ tdc. Use the adjustable push rod,to show you the length. Maybe not exact , but pretty close, in most apps/ Just one last thought....do not guess on the length....longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
