Old 11-02-2015, 09:58 PM   #26
Becker67
Becker67's Avatar
Re: Finally got the 4.5/6 drop finished
Nice looking truck here's my truck with 255/60's in the front and 275/60's in the rear
Kevin
67 custom cab big window swb 350/700r4 4/6 drop tilt,a/c
69 custom/10 swb 350/350 4/6 drop tach,tilt
71 cheyenne super swb 454/700r4 4/6drop tach,tilt,a/c,bucket seats,speed warning
96 gmc swb
Becker67 is offline   Reply With Quote
Old 11-04-2015, 12:41 AM   #27
Malamute
Malamute's Avatar
Originally Posted by NTIMID8R View Post
That looks great. Did you have to notch it and did the control arms clear the rims without modifying them?
No notch and the control arms clear the wheels with no grinding. That was my biggest worry and why I was thinking about going with a larger wheel but now that I see the 15's on it, that's the way it will stay. I would love to find a set of 15x8 steelies at some point.
Malamute is offline   Reply With Quote
Old 11-04-2015, 12:42 AM   #28
Malamute
Malamute's Avatar
Thanks, I'm pretty sure that is what I will be running as well. I mentioned darker gray paint on the rally's, it looks like yours are a little darker than normal. Did you paint them?
Old 11-04-2015, 10:14 AM   #29
Rod Run
Rod Run's Avatar
Great looking drop
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 11-07-2015, 11:14 PM   #30
Becker67
Becker67's Avatar
They were powder coated rally wheel silver
Kevin
96 gmc swb
Old 11-08-2015, 10:51 AM   #31
Malamute
Malamute's Avatar
Thanks.
Old 11-14-2015, 01:57 AM   #32
Rafa72cheyenne
Rafa72cheyenne's Avatar
NICE !!!!!
I fnished my 4.5 drop today on the front. cant wait for my 6" coils to get here.
ill be at the same stance as you in a couple days !
-RafaeL
Rafa72cheyenne is offline   Reply With Quote
Old 11-15-2015, 07:24 PM   #33
Malamute
Malamute's Avatar
Three better shots today. Cleaned up the surface rust in the rockers and after pulling the carpet from the kick panels we found some bondo at the bottom on each side. Grinded it out and there was just a little rust where the kick panels join the floor.
Got everything patched, placed some seam sealer and POR 15. Put the new weather-stripping on the doors as well. Going to stay with the current carpet, just going to steam clean it the best I can and then it's time to wax that paint and see if I can get a little oxidation off of it.
I'm open to suggestions on the best product to use on the paint.
Old 11-15-2015, 08:24 PM   #34
Rafa72cheyenne
^^ nice truck!!!
-RafaeL
Old 11-15-2015, 09:11 PM   #35
70 shorty
Where's my beer?
70 shorty's Avatar
I think that's about as perfect as I'd like my 70 to sit. Love it!
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 11-16-2015, 09:21 AM   #36
Green67Stepper
Green67Stepper's Avatar
I may have just missed it, but what kit did you run?
Green67Stepper is offline   Reply With Quote
Old 11-16-2015, 11:08 AM   #37
lolife99
67-72 parts collector,…
lolife99's Avatar
Your truck looks great.
I'm saving this pic.
A lot of people don't understand how much wider the front track width is on these trucks.
Especially the 67-69 trucks with the narrower rearend and disc brakes added in the front.
It's just a pet peeve of mine.
Skip the waxing and go right to buffing with good 3M products.
You will be amazed.
Then give it a coat of wax.
Keith
Convert to disc brakes.
Old 11-16-2015, 04:23 PM   #38
Boog
laying low
Boog's Avatar
You can put a 10" wheel and tire on the rear and it will fit and look like its made for that truck.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-16-2015, 05:48 PM   #39
Malamute
Malamute's Avatar
ECE 4.5/6 w/ 4 wheel discs.
If I could find a 10" wide 6 lug rally I believe that is what I would put on the back.
Old 11-16-2015, 08:09 PM   #40
Boog
laying low
Boog's Avatar
http://www.summitracing.com/parts/wvi-42-5006044
There you are.
Boog
primer is finer
Old 11-16-2015, 08:50 PM   #41
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Seriously sweet truck.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 11-17-2015, 01:13 AM   #42
Malamute
Malamute's Avatar
You will be amazed.
Thanks. I'll see what products I can find and hit it with the buffer.
Thanks. I could just swap the caps and trim rings over. I do think it would look better with a wider rear wheel.
Thank you.
Old 11-17-2015, 05:41 PM   #43
GeirJB
GeirJB's Avatar
Nice! Good looking truck! Like the stance! I want to do same with my -67!
MY -67 Chevrolet C-10, http://67-72chevytrucks.com/vboard/s...d.php?t=622636
Other Cars -69 VW 1600 Variant, 82 VW Polo G40, - 96 Subaru Impreza GT Turbo, -01 BMW 316ti
GeirJB is offline   Reply With Quote
Old 11-18-2015, 10:54 AM   #44
Malamute
Malamute's Avatar
After some research it looks like 3M Finesse it in a medium grit may be the way to go.
Thoughts on the grit?
Old 11-18-2015, 11:18 AM   #45
lolife99
lolife99's Avatar
Here's what I used on Gingers cab.
#1 rubbing compound with a wool pad has amazing results, but move quickly and stay off of the corners. The original lacquer paint on my truck was thin.
Then followed up the last two compounds with the correct foam pad.
It even bought a new buffer for this job.
I figured it was a good investment and way cheaper than a new paint job.
Take your time and have fun!
Keith
Old 11-18-2015, 11:45 AM   #46
knomadd
knomadd's Avatar
Keith is right on with the 3M stuff and how to use it. I believe the #2 uses the white/cream colored foam pad while the #3 uses the dark gray foam pad. The white/cream pad is a coarser foam than the dark gray, which helps each compound do its job. (Assuming you are getting 3M pads. I can't speak for other brands colors).
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-18-2015, 12:11 PM   #47
Malamute
Malamute's Avatar
Thanks! Is an auto body supplier the best place to get this stuff or do the local parts stores have it? I want to have the right pads as well for the buffer.
Old 11-18-2015, 12:17 PM   #48
lolife99
lolife99's Avatar
You can usually find these products anywhere that sells paint.
I got mine at my local auto parts/paint supplier.
But they keep these 3m products in the back.
Be prepared to spend a few bucks,... But its worth it.
Keith
Old 11-18-2015, 01:09 PM   #49
original-71
///Relaxed Atmosphere
original-71's Avatar
I went that route also and it is pricey but the products do work. or try amazon they have the entire kit plus all the pads for $132 and free shipping....seems like a deal and shipped to your front door. looks like only 2 left at that price though
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 11-18-2015, 01:34 PM   #50
lolife99
lolife99's Avatar
That is a good price!
Keith
