Old 11-02-2015, 10:40 PM   #1
kdearing
1970 gmc rearend
Would axles out of a 78 Chevy fit back in the 70 gmc rearend. Haven't ever messed with the gmc stuff and wasn't sure
kdearing is offline   Reply With Quote
Old 11-02-2015, 11:40 PM   #2
swamp rat
swamp rat's Avatar
Re: 1970 gmc rearend
Thats an open question, 2wd, 4wd, 1500, 2500, leaves, coils.. Chances are yes it would need different spring and shock mounts.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-03-2015, 12:18 AM   #3
nlped
nlped's Avatar
Axles or housing? The axles in a 73 up rearend are longer than either length 67-72's. 73 up Housing will "fit" with new perches & possibly shock mounts (leaf or trailing arm?).
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-03-2015, 12:56 PM   #4
michael bustamante
michael bustamante's Avatar
axles will not slip in either 67-72 length housing. are you trying to switch to 5 lugs. early classic i think sells the shortened 5 lug axles. but 70 is a dual length axle year. youll have to measure the rear end before you order
1967custom
michael bustamante is offline   Reply With Quote
Old 11-03-2015, 11:16 PM   #5
volksworld
when i put the 73 rear in my 70 leaf spring chevy the 70 6 lug axles and drums went right in and worked fine...after i converted to front discs i put 5 lugs back in....i believe 67-69 housings were narrower and axles shorter
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 11-04-2015, 08:25 PM   #6
Tireguy87
1970 GMC 2wd SWB leaf spring rear. The plan was to take the axle shafts out of a scrap '78 2wd truck and swap them into my 1970 axle shafts in order to convert to 5 lug.
Tireguy87 is online now   Reply With Quote
