Old 11-02-2015, 11:01 PM   #1
chuchito
Need help figuring out my fuel lines on my 1972 suburban
Does anyone know how the fuel lines are supposed to be routed from the fuel pump to the rear gas tank on a 1972 suburban? My gas tank was removed to install a new one by a shop an now I'm trying to figure out how to install the new one since they just left it.
I don't think that the engine on my burb is the original after researching the suffix code on the engine block(TJC). It currently has a fuel pump with 3 outlets. 1 is to go to the carb and the other two go to the back. Does anyone know where those two lines that go to the back connect to? How are they supposed to be attached to the gas tank( which fittings on the gas tank go to what?). A diagram would be great.
I see diagrams for the trucks but none for the suburban.
chuchito is offline   Reply With Quote
Old 11-03-2015, 08:35 PM   #2
rocknss
rocknss's Avatar
Re: Need help figuring out my fuel lines on my 1972 suburban
If a 72 is the same as my 69 Burb you will have a rubber hose coming from the tanks sender to the hard line on the frame rail. On mine the hard line is in two pieces with a rubber hose connecting them together. I then have a rubber hose from the hard line to the pump. Then the line goes to a filter and then the Carb.
I'm not sure what the third connection on your pump is for.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 11-03-2015, 09:14 PM   #3
chuchito
Thanks Rocknss. That's why I am confused as mine has that extra line. Do some Suburbans have different fuel lines for some reason?
Old 11-03-2015, 09:57 PM   #4
Bigdav160
Bigdav160's Avatar
Do yourself a favor and download your service manual here
A diagram of the fuel line routing is in section 8
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-04-2015, 03:40 PM   #5
chuchito
Thanks Bigdav160. I will take a look at those.
Old 11-06-2015, 03:18 AM   #6
jfalesi
Junior Member
C/K 10's have evaporative emissions control (EEC) lines that run from the engine back to the tank and to the charcoal canister. The diagrams in the service manual will help, but I found them to be less than stellar, especially for routing the hard lines. Check the link below for what mine look like at the moment (I'm in the middle of installing a new tank). PM me your email address and I'll send you the pics that Franks 72 sent me. I'll take some more pics of where the lines go on the tank too.
http://67-72chevytrucks.com/vboard/s...d.php?t=685244
jfalesi is offline   Reply With Quote
Old 11-06-2015, 06:19 PM   #7
chuchito
Jafalesi, I sent you a pm. Yes, I especially need pics of where they connect to on the tank and on the canister you mentioned.
Old 11-06-2015, 08:49 PM   #8
Bigdav160
Bigdav160's Avatar
I thought the service manual pictures were pretty good
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 11-06-2015, 11:13 PM   #9
chuchito
Bigdav, that first picture is a little confusing. Is that for the Suburban? It has the arrow pointing towards the front. If that's the case, it looks like all the hoses are plumbed from the tank over to the rear drivers side where the you would fill the tank from. I don't see any hoses from the tank towards the front right side frame. Am I looking at this picture all wrong? Sorry for my ignorance.
Old 11-07-2015, 08:18 AM   #10
Bigdav160
Bigdav160's Avatar
The two lines on the top of the tank are the vents and they go to the fuel separator on the drivers side. The third line goes from the bottom of the separator across (at the bottom of the pic) to the passenger side and connects to the fuel supply line.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 11-07-2015, 11:49 AM   #11
chuchito
Got it Bigdav! I don't see that I have the fuel separator you are referring to. The below pic shows what came off of my burb.
Old 11-07-2015, 11:51 AM   #12
chuchito
Extra pictures
Old 11-07-2015, 11:52 AM   #13
chuchito
Side view of passenger rear.
Old 11-07-2015, 11:55 AM   #14
chuchito
Side view of drivers side rear.
Old 11-07-2015, 02:04 PM   #15
Bigdav160
Bigdav160's Avatar
From the inside, the separator looks like a tube just to the left side filler. under the truck it looks like three pipes hanging down.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 11-07-2015, 07:32 PM   #16
chuchito
Are all suburbans supposed to have this or only certain ones? Mine doesn't have that anywhere.
Old 11-07-2015, 10:08 PM   #17
Bigdav160
Bigdav160's Avatar
Good question.
Mine has California emissions and this is all in place. These pictures are from the '72 Service manual but it doesn't differentiate between California and the other 49 States.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 11-08-2015, 02:55 PM   #18
chuchito
I ordered a book for my suburban and I think I figured it out. This picture is from my book and it doesn't look anything like the pictures from Bigdav. Mine is a GMC. Maybe that's the difference, I don't know.
Old 11-15-2015, 07:59 AM   #19
Mikmark
My 72 has two lines that run to the fuel tank. One brings fuel from the tank and the other returns fuel back to the tank. I think this was to help keep the fuel cooler and avoid vapor lock. The original fuel level guage that fits in the gas tank had a port for the return line. The replacement ones that I have looked at do not have this extra port. I just ran the return line to one of the vent ports. Works OK so far.
1972 C10 Suburban
1959 Austin Healey Sprite
1977 Datsun 280Z
Mikmark is offline   Reply With Quote
