Old 11-04-2015, 03:16 PM   #1
In The Ten Ring
Last bit of warm weather: what are you getting done?
Here in WV, this is probably the last bit of good weather before winter comes. I am finally getting my grill top coated in "argent silver."
What are you guys getting done to your trucks?
In The Ten Ring is offline   Reply With Quote
Old 11-04-2015, 03:26 PM   #2
EARNHARDT#3
EARNHARDT#3's Avatar
Re: Last bit of warm weather: what are you getting done?
Automatic transmission swap. I was going to wait until spring to do it but I already gathered all the parts. Now the weather has been so nice that I decided to get it done. It's too crammed in my garage so I'm doing it in the driveway.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 11-04-2015, 03:41 PM   #3
cooperhw
cooperhw's Avatar
With the "last bit of warm weather" here in Arizona we actually kick it in high gear. Finally made it through another hot a** summer. About 5 months of perfect weather coming. Yeah. Now that I have finished bragging.
I am hoping to finish my 68 dually build completely. Hoping to get back on my 67 Nova drag car and get it where I can take it to the track. And, if I sell my Chevelle I will start doing my 63 GMC S.B. fleetside.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 11-04-2015, 03:43 PM   #4
Fitz
But it's a DRY HEAT Coop!
Fitz is offline   Reply With Quote
Old 11-04-2015, 04:47 PM   #5
Lou Boffa
Lou Boffa's Avatar
HA! same here. Gotta tear apart the driver's side door to fix the regulator. Also want to redo the capture nuts on both door panels. Also going to re-wrap the wiring with Classic Braids from Painless. Fun stuff.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 11-04-2015, 05:58 PM   #6
dmartin1
dmartin1's Avatar
Now is the time we south-westerners get stuff done.
i imagine back in the cold wouldnt be TOO bad with a big garage and a heater
anyhow, i am doing a c-notch and flip kit on my 94 extra cab shortbed i put a motor in(very clean truck)runs like brand new but i have a driver 06,idk what ill do with this 94?
trying to button up more on my 69 shortbed fleetside,seems like i never get anything done to it.
and maybe one day get the block done from the machine shop for my 468 build
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 11-04-2015, 06:12 PM   #7
hugger6933
I built a cab flipper dolly the other day and work a little more on Wiggy's cab about ready to pull it.
hugger6933 is offline   Reply With Quote
Old 11-04-2015, 06:52 PM   #8
midniteblues
midniteblues's Avatar
Just playin with this stepper.
This morning the kid an I hit up a flea market and I picked up a few items. But anyway I finally got every lite working I needed license plate lites (2new ones at the flea market $1apiece).
They were done first.
Then I crawled under an put a reverse switch in the granny 4.
That got them workin.
Then I tackled the job of re wiring the alt.
Since the motor was replaced with a lwp motor so the alt is on the wrong side and the po. had a nasty mess of wire too reach over there. I used a old hacked harness and soldered the wires to run across the core support back too the battery then over too the alt.
Looks much better now and not a fire hazard.
In doing the last thing tightening the alt belt I snapped the bolt on the alt...ugh.
Out came the alt welded a nut onto the bit of bolt left it took me four nuts but finally got it out.it was really in there.
As the sun set I continued to rinse some of the farm mud off the underside of it.(hope that was mud)
Then I took it for a ride around the back roads for a bit.
Now I getting ready to replace the float on a sending unit.for the other.
All fun fun fun.
Tomarrow we pull wheels on the stepper and check out the brake stuff.
The fella told me the brakes didn't work but the kid put fluid in an we haven't had a problem with them once it had juice. probably bleed them tommarow I'm sure it'll help.
How's that for getting sumtin done.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-04-2015, 07:03 PM   #9
Redline novdog
Redline novdog's Avatar
It's close to 70deg here and I just got the hood to cowl seal from Wes at Heartbeat. Had to drop everything else and install !! Thought for awhile it was gonna put me down,but removed the cowl after trying other methods! It fits good and let it snow!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 11-04-2015, 07:15 PM   #10
In The Ten Ring
Originally Posted by Redline novdog View Post
Attachment 1463542
Attachment 1463543
Attachment 1463544
Attachment 1463545
Good to hear. I need that weatherstrip replaced too.
Can you hit us with pics on how you did that screen under your cowl?
Old 11-04-2015, 07:34 PM   #11
Redline novdog
I did not do a photo build. Was not worthy of the time. Basicly laid the Gutter screen down and used a sheet metal shears to cut it around the wipers. the washer nozzles made me do it twice because of the put it over the nozzle and slide foward.I'm not a real fabricator. But I slept at Holiday in Express. HA! LOL!
Old 11-04-2015, 07:41 PM   #12
67ChevyRedneck
67ChevyRedneck's Avatar
I got the nose job done last weekend:
I just wanted to redo my drip rail and replace the rear window/seal but found some very unwanted rust.
There was about +/- 15-20 pinholes I drilled out and filled in. Came out pretty good. I also used my new stud gun and pulled out a couple dents! Instead of 1/8-3/16" of filler in those spots, should just be a skim coat. First time using it, was pretty easy.
I got the DS drip rail all repaired and new sealant but I still have to do the PS (much cleaner/better than DS!) and above the windshield, get it primed and repainted white, but the weather keeps being crap. It's rained like 3 of the past 5 weekends (like, ALL weekend fri-sun) and they're calling for rain all freakin' weekend again.
I've been at this same point for about a month.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-04-2015, 08:07 PM   #13
wreckedchevy
wreckedchevy's Avatar
heck with working on it i'm just going to keep driving it! I do have to get some material this weekend and try and finish my secret project before I get froze out of my garage.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 11-04-2015, 08:22 PM   #14
EARNHARDT#3
67ChevyRedneck....I REALLY like your truck and the things you've done to it. Looks like you're really having fun with it!
Old 11-04-2015, 08:24 PM   #15
iostorm
pulled off the bed and power washed the frame, next off is the front clip, then engine trans, then cab....
iostorm is offline   Reply With Quote
Old 11-04-2015, 08:45 PM   #16
Redline novdog
http://67-72chevytrucks.com/vboard/s...d.php?t=553767
This has some more cowl screen material!
Old 11-04-2015, 08:48 PM   #17
67ChevyRedneck
'Preciate it!
This is her 3rd makeover in 18 years
Some of you would be shocked to know I owned a truck that long and drove it stock height all that time!
In all honesty... it rode better stock. The drop is OK, but definitely a little "bouncier" and a bit more "stiff" than before. But still, not a huge difference, just enough to notice it.
Jesse James
Project "On a Dime"
Old 11-05-2015, 07:37 AM   #18
Don't worry, this winter will be milder for us in the Mid-Atlantic, I promise. I'm trying to get time to finish up the 4" lift, and general service/freshen-up on my '72. Got things painted that need paint and most of it together. Almost ready to bolt the aluminum slots on and roll it! Once the salt hits the road (got through December last year) I'm considering going ahead with the engine rebuild. If I can buy the 383 kit I will pull the engine and start. I'm sure I can pull the rest of the funds together as needed.
Old 11-05-2015, 08:01 AM   #19
midniteblues
[QUOTE=special-K;7365603]Don't worry, this winter will be milder for us in the Mid-Atlantic, I promise.
I hope your rite.
Here dang near all the trees are bare,nothing but all black cattapillers (you know what they say about them).
And everything I hear says a bad winter ahead.
It shouldn't be so bad though if fuel prices stay down.
I got frustrated last nite 3 floats and they all have holes.
Old 11-05-2015, 08:11 AM   #20
CUSTOM/10
CUSTOM/10's Avatar
Huh..... I'm raking leaves and stacking firewood !!!! Haven't touched the truck in over a month... Grrrrrr....
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 11-05-2015, 09:13 AM   #21
I am way behind on my firewood situation. Mild or harsh, I need to fill that shed!
Old 11-05-2015, 09:26 AM   #22
Youey
I put leaves and wood aside this month to try and get my dam truck on the road before it snows. I'm getting very close but still far from done. Been getting a lot of work done on it, replaced wheel bearings yesturday and painted rally's, also coated my bed with rhino liner, gotta finish up installing newly rebuilt vent windows and get all my gauges working and maybe just maybe I'll be able to take it down to the gas station for the first time!
Youey is offline   Reply With Quote
Old 11-05-2015, 09:33 AM   #23
Grumpy old man
Grumpy old man's Avatar
Pressure washing the project trucks before putting them in dry storage While it's still warm here , pulling engines for winter rebuilds , selling extra parts and building new door panels and seats for the 67 short bed that's almost done .
http://
Old 11-05-2015, 09:33 AM   #24
CUSTOM/10
CUSTOM/10's Avatar
I cut down 7 trees, 2 big maples, and bought 4 cords cut & split, so about 7 cord all together, have around 2 cords left to stack. Did one leave clean up and will have at least one more. The next thing will be to get the snow blower on the tractor and check it out. Then maybe I'll have some time for the truck !!!
Gary
72 SWB 4x4
My 72 SWB Build
Old 11-05-2015, 10:04 AM   #25
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Just rebuilt this OEM slider for use in the GMC. The existing (old) gasket around the aftermarket (old) slider leaks so thought I'd rope in this OEM piece before the temps drop further. First freeze is expected tonight.
