Old 11-04-2015, 09:35 PM   #1
72farmer
How hard to find this 70 axle?
I pulled the axle out of my 6 lug 67 today.It has wear where the bearing runs.I thought I had the problem under control because I had a friend that had a couple of used ones.
We compared them and mine was about 3/4" longer.I found the numbers on my rearend TDE 0922W2 and I think it is a 1970.I bought a relocator bearing/seal and I am going to try it.How hard would it be to find a used axle this length?Aint measured it yet but it is about 3/4" longer than the 67 axles.
72farmer is offline   Reply With Quote
Old 11-04-2015, 10:10 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: How hard to find this 70 axle?
Yes, the '70-'72 rears were wider by 3/4" on both sides, 1 1/2 inches overall.
The TDE would be a 3.07:1 out of a '70 C-10.
LockDoc
Leon
Old 11-04-2015, 10:34 PM   #3
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Try ROCKAUTO. They probably can do it.
TobyArnot is offline   Reply With Quote
Old 11-04-2015, 11:00 PM   #4
Ruscal
Check with Moser maybe.
Russ
RC
Ruscal is offline   Reply With Quote
Old 11-04-2015, 11:39 PM   #5
fp1967
fp1967's Avatar
Should be easy to find a replacement axle I would think. The 4wd's used the 6 lug axle this same width up until they quit using 12 bolt axles. I can't remember what year they switched from 12 bolt to 10 bolt axles, I think it was around 82 or 83.
fp1967 is offline   Reply With Quote
