#401 |
Re: My 52 GMC Build
looking good man
big_moss bagged 51 3100 build |
#402 | ||
Re: My 52 GMC Build
![]() Thankyou big_moss
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#403 |
Re: My 52 GMC Build
Well over the weekend the fam and I went to visit the inlaws. I had about $2000 of parts delivered to a friend of there's in the US. They go down about 5 times a year with there 5th wheel and brought all my parts back. (Saved shipping to Canada and duty)
#404 |
Re: My 52 GMC Build
So today I painted and mounted my sway bar. Have to make some A arm mounts tomorrow to attach the sway bar. Also pulled the spindles off and got them modified for putting my Willwood brakes on. It says to cut the caliper ears off and drill and tap the 2 holes to move the caliper out for the bigger disks.
#405 |
Re: My 52 GMC Build
Today I got the passenger side all put together. New 3/8" rubber air line did away with the push lock, sway bar mount and hooked up, new bolts for suspension, and Willwood brakes.
#406 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: My 52 GMC Build
Those new brakes and hubs look sweet!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#407 |
Re: My 52 GMC Build
Thanks Diesel!! Wilwood Make some nice products.
So today I got the drivers front brakes on and finished up with the front suspension then did a test fit with the new 255/50/16 tires.
#408 |
Re: My 52 GMC Build
Very nice! When's your time in the booth?
#409 |
Re: My 52 GMC Build
Very nice lowers....but a set of Alcoa 19.5" wheels would look so sweet on that truck.
#410 |
Re: My 52 GMC Build
Booth?
Ya they would look sweet. I built the truck for a 26" tire so if I went with the 19.5" Alcoa wheels I would have about a 3" side wall. Maybe some day.
#411 |
Re: My 52 GMC Build
I have to thank my friend Joe for helping me put my windows in last night. He has the tools and knowledge that made it a piece of chocolate cake. Rear window was in in less than half hour and the front a little longer.
My helpers last night cleaning the crud off windows. This tool was for putting the lock bead in the rear seal. ![]() Then we had to put the visor back on. ![]()
#412 |
Re: My 52 GMC Build
looking good
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#413 |
Re: My 52 GMC Build
Do you know what size the piston bore is on your Wilwood calipers. I am building my own front setup and was wondering what the kits came with, 1.38 or 1.75?
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#414 |
Re: My 52 GMC Build
Good looking brake upgrade. Gotta love big shiny disc brakes. Also like the idea of putting the kids to work cleaning windows.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#415 |
![]() Join Date: Jul 2012
Re: My 52 GMC Build
Great idea having the kids involved!
#416 |
Re: My 52 GMC Build
Thanks guys it's so exciting!
1.2 X4 total piston area is 4.80. Wilwood caliper # 120-6816-RD
#417 |
Re: My 52 GMC Build
Nice, one step closer! Lookin good
#418 |
Re: My 52 GMC Build
Thanks for the info lower50's.
#419 |
Looks awesome lowered. It's great having the kids out with ya isn't it.
Posted via Mobile Device |
#420 | |
Re: My 52 GMC Build
ghettoluxury no prob
#421 |
Re: My 52 GMC Build
Bought my batteries last night. I have been working on finishing up the wiring in the bed, looks great. The big continuous duty relay is for my compressors. The little cube relay is for my trans cooler and the bolt is a chassis ground. This is one reason my batt trays are so big. I also hooked up my 3/8" rubber air line to the front that I replaced when I did the brakes. I installed flow controls for down on the front and up on the rear so I can make it go up and down evenly. Air gauges are mounted just beside vent leaver.
#422 |
Re: My 52 GMC Build
Last night I got the box together I'm trying to get some parts back on so they aren't lying around getting scratched. In the front where the hinge for the bed goes I put in some 1/4" nut certs. Then to fit the tailgate first 2 bolts in bumper then 2 more through apron then tailgate can go on and tighten it all down. LOL
Also installed cowl vent ![]()
#423 |
Re: My 52 GMC Build
Looking really good!!!! I really like this truck, lots of creativity within the entire thing.
Did you go with the 12.19" rotors or bigger? love the Wilwood stuff. Also was just checking back on your "scrapers"..... you should get yourself some magnesium plates and add them to the bottom, so when you drag bottom you can shower the night with pretty colorful sparks!!!! ![]()
My Build: 57 Chevy Pro-Street |
#424 | |
Re: My 52 GMC Build
#425 |
![]() Join Date: May 2007
Re: My 52 GMC Build
I cant believe you dont have an engine driven compressor on that diesel. I know someone makes one! it will change your life, you know what the recovery time is for a lift? 12 SECONDS. 12. if you have a leak and your tank goes empty overnight, filling from slap empty is under 2 minutes.
I love how the inside tires are even with the bed wall, gave me a chuckle.
Tags |
bagged, build, diesel, gmc, hot rod |
