Old 11-08-2015, 02:13 PM   #1
Handmedown
Handmedown's Avatar
Steering mystery
So my steering works fine when the engine is not running, with the front wheels off the ground it turns fine in both directions. when the engine is running it turns fine to the left, but it takes all my strength to turn it to the right. what gives?
Handmedown is offline   Reply With Quote
Old 11-08-2015, 02:27 PM   #2
sduckworth13
sduckworth13's Avatar
Re: Steering mystery
Sounds like your power steering pump. I was having a similar issue with a brand new one I recently put on. I swapped it out and haven't had a issue since.
Scott
sduckworth13 is offline   Reply With Quote
Old 11-08-2015, 02:27 PM   #3
hugger6933
So I assume it is a power steering type truck then if so you have a pressure problem in the pump. the pressure relief valve is in the back of the pump where the pressure line screws into the back where that huge nut is. I bet your problem is right there.
hugger6933 is offline   Reply With Quote
