Old 02-23-2004, 12:21 PM   #1
Bram
Broke
Bram's Avatar
Question SB Motor Mount Bolt
Ok everyone, I need some help.
Here is the problem, I have the small block motor mounts mounted on the engine right, well my problem is the single bolt that goes up through the middle of the tower into the motor mount, (By the way this is a 72 4x4). I need to know the length of the bolt and any other hardware that goes with it, lock washer ...etc?
The problem is I can't find the original hardware I pulled out, since I cleaned out my shed, so I’m relying on my memory which is gone. The tower hole where the bolt goes is pretty large, and I can't remember if there was a rubber piece or just a washer, or what?
Can anyone help me out, it sure would be appreciated.
72CheyenneSuper1ton4x4BigBlock
Bram is offline   Reply With Quote
Old 02-23-2004, 02:28 PM   #2
rage'nrat638
rage'nrat638's Avatar
9/16 X 1" WASHER AND A LOCK WASHER WILL BE FINE
rage'nrat638 is offline   Reply With Quote
Old 02-23-2004, 02:44 PM   #3
Bram
Broke
Bram's Avatar
I don't understand? The bolt goes through the tower, and threads into the motor mount, is there room to get behind the mount to put on a lock nut?
Also when I put a bolt in, the only thing that keeps it from going through the tower is the washer. When I tighten it down the washer starts to bend in? This is why I thought I was doing something wrong?
Old 02-23-2004, 03:02 PM   #4
rage'nrat638
a lock washer sorry
try a smaller washer...how big of a washer are you using?
Old 02-23-2004, 03:25 PM   #5
Bram
Broke
Bram's Avatar
That's the problem, if I use the correct size washer it goes right through the hole. I tried using an oversized washer but then it bends.
Does anyone have any pictures of the 72 4x4 motor towers? I want to check and see if mine are the same.
Old 02-23-2004, 08:24 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
WHOA! I'm calling foul on this one!
That isn't a 9/16 bolt. It's a 3/8 x 1 inch long bolt. Yes, a 9/16 wrench or socket fits it, but that don't make it a 9/16 bolt.
For the washer, I use old harmonic balancer bolt washers on mine. They are thick as hell, have the right 3/8 size hole in them, and they are real big around so they don't go into the hole.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-23-2004, 10:36 PM   #7
tom hand
CCRider
tom hand's Avatar
Hmmmm..mine has a 7/16 14 x 1 bolts...pretty sure it's factory...anyone else?
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 02-24-2004, 12:56 AM   #8
Bram
Broke
Bram's Avatar
I guess I don't understand why they made the hole so big in the first place? Wouldn’t it be stronger to have the correct size hole? Or does it give it enough slack with the bigger hole that when the engine moves forward or backwards a little it's less likely to break? I don't know, I guess I'll find the toughest washer I can, and torque the SOB down so my Big Block won’t rip them out.
Old 02-24-2004, 02:38 AM   #9
kwmech
I have used 7/16-14 x 1.25'' long with the harmonic washers and a lock washer.
Old 02-24-2004, 07:44 AM   #10
Tx Firefighter
I am a moron. I just put my big block in on Saturday and yes, they are 7/16 bolts. I have no idea why I said they were 3/8 inch. But, never the less, I used the harmonic balancer washers to compensate for the big holes.
Old 02-24-2004, 10:00 AM   #11
JimKshortstep4x4
Talking
The factory ones are 7/16-14x1 1/4" (not positive on the length, 1" will work). The were set up with extra thick washers and lock nuts. Harmonic balancer washers will work fine but you may have to compensate for length since the balancer washers are very thick.
Jim
