Old 11-14-2015, 03:52 AM   #1
slotard
Headlight switch knob
The headlight switch knob on my '73 broke off, leaving only a threaded metal post to turn the headlights on/off. I can live with it, but it would be nice to have it back how it should be. I'd rather not replace the entire switch assembly if I don't need to. When I went to my local auto parts store they couldn't help.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 11-14-2015, 08:03 AM   #2
LeesTruk
Re: Headlight switch knob
It's easy to replace the entire shaft/knob. Just reach under the dash and locate the flat bottom side of you headlight switch. There'll be a wiggly type button on it. Just push in the button, then pull out the shaft (while still holding in the button). To insert a new shaft, just push it back in. Just be aware, that pulling out the shaft will also turn on your lights, so either be quick or disconnect the battery. If you can't locate a shaft/knob, PM me and I can send you one (probably won't match yours but will work just the same)
Lee
LeesTruk is offline   Reply With Quote
Old 11-14-2015, 11:03 AM   #3
bmchevy1979
bmchevy1979's Avatar
Also 73-74 used a slighly longer shaft on the knob to clear the bolt that secures the switch to the dash if you don't have the original gauge bezel you can use the shorter ones as long as you use the later flat bolt on the dash. I believe classic industries carries the original style ones though
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
