Old 11-17-2015, 12:13 AM   #1
juddss
What drive shaft to use
Just totaled my 04 cts V and thinking of buying it back and installing the LS6 and T56 in my 70 suburban. Also may add the 2010 Cts v blower I have on top of it.
My question is what driveshaft are you guys using the stock one and just changing the length of it. I have the the driveshaft from my Cts v so was thinking of bringing it to a local driveline shop and having the front yolk adapted onto the stock driveshaft.
I wonder how much my stock driveshaft can handle??
juddss is offline   Reply With Quote
Old 11-17-2015, 03:56 PM   #2
foamypirate
foamypirate's Avatar
Re: What drive shaft to use
I would scrap the idea of using a stock shaft, especially if you are planning to put a supercharger on it. Your stock driveshaft was designed to live behind an engine making maybe 180HP and turning lower overall speeds than you would with an overdrive trans like a T56. A new aluminum driveshaft isn't super expensive. It's worth the upgrade.
foamypirate is offline   Reply With Quote
Old 11-18-2015, 10:13 PM   #3
Jon01
Jon01's Avatar
Buy a new shaft.
How are you going to put a blower designed for rectangle ports on a cathedral port head?
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 11-18-2015, 11:58 PM   #4
foamypirate
Originally Posted by Jon01 View Post
Buy a new shaft.
There are a few people/companies that make adapters. Not sure how they impact flow, but that's somewhat of a moot point with forced induction, I suppose.
Old 11-19-2015, 10:10 AM   #5
Hart_Rod
Hart_Rod's Avatar
Check out the Drive Shaft Shop
Hart_Rod is offline   Reply With Quote
Old 11-19-2015, 04:57 PM   #6
Willie Makeit
Willie Makeit's Avatar
Buy a new shaft.
i'm planning on using these.
http://www.ebay.com/itm/LS1-Cathedra...lWTi0i&vxp=mtr
Willie Makeit is offline   Reply With Quote
Old 04-08-2016, 10:26 PM   #7
juddss
So I ended up building a 6.0 with CTS V LSA blower and heads with brian tooley stage 3 camshaft. I will problbly be making anywhere from 600 to 625 HP. I plan on starting the swap in the next month. So the stock driveshaft will probably grenade or snap in half correct?
So far I have a Th400 built for boost with a Sunex forged yolk. I may install a gear vendors overdrive unit on the back of the transmission. From what I understand I should keep it a 2 piece driveshaft with a carrier bearing Correct?
I believe a one piece shaft will have a vibration.
Old 04-08-2016, 11:16 PM   #8
72MARIO
72MARIO's Avatar
I put a 1 piece in my suburban with a GV unit and even with my pinion angles correct I still have a vibiration. I will be going back to a 2 piece to try and resolve the vibiration
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
