Old 11-17-2015, 01:57 PM   #1
scott657
scott657's Avatar
62 and 63 cab
Are 62 and 63 C10 cabs interchangeable?
Scott
63 C10 Stepside
230 1bbl
Saginaw 3 spd
scott657 is offline   Reply With Quote
Old 11-17-2015, 02:18 PM   #2
PGSigns
PGSigns's Avatar
Re: 62 and 63 cab
Frame changed in 63 but not sure if the mounts moved.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-17-2015, 02:42 PM   #3
1963c-10
1963c-10's Avatar
Re: 62 and 63 cab
Yes, the mounting position on the cab changed in 63 also. 60-62 cabs and frames and 63-66 cab and frames are interchangeable without modification
1964 Short bed trailer
Old 11-17-2015, 02:55 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 62 and 63 cab
Careful of the series your dealing with and 4X4.
The 1963 Cab was a replacement part for damaged 60-62. There were templates for drilling for the additional hole for the hydraulic clutch/ brake master cylinder and for the wider frame mounting locations.
