11-19-2015, 06:30 PM | #1 |
downpipes
Hi guys,
My 65 LB has a nice 327 with straight 2" rams horns. Since I have lowered it 5" I want all the exhaust above the frame and out to the rear bumper. I have moved the trans linkage and have a new trans crossmember with plenty of clearance. I'll cut holes in the trailing arm crossmember. All this seems to be pretty standard , so the exhaust system must be common. Who makes downpipes in 2 1/4" tubing that fit this? Thanks,W |
11-19-2015, 06:32 PM | #2 |
Re: downpipes
Take it to a local exhaust shop & have it made.
11-19-2015, 06:33 PM | #3 |
Re: downpipes
You are going to have to visit a local shop and have it bent to fit. Nothing off the shelf is going to work.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11-19-2015, 06:53 PM | #4 |
Moderator
Re: downpipes
Hows your driveline (drive shaft) look at that height going through the crossmember?
11-19-2015, 08:13 PM | #5 |
Re: downpipes
My 63 lwb is lowered quite a bit. Had my muffler guy route the exhaust on the outside of the frame rails from the ram horns all the way to the back. Oldschool sound with Brockman's. No clearance issues with the exhaust.
11-20-2015, 05:53 PM | #6 |
Re: downpipes
Well, the quote was $500.
That's why I asked. Since so many of the build threads make use of rams horns, and thru the crossmember routing, I thought someone would have been fabbing a whole system for this app. Thanks, W |
11-20-2015, 06:02 PM | #7 |
Re: downpipes
$500 is not bad at all. I dropped my GMC off to get exhaust work done...its stock stance with a 305 V6 and the quote was $400 with the mufflers.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
