Old 11-20-2015, 09:46 PM   #1
okie6801
Stock windshield tougher than new aftermarket?
I have the original wind shield in my 71. It does not have a peck in it but a litte "smokiness" on the very edges due to delamination over the years. I am thinking about replacing with new but am afraid an aftermarket would be more fragile. Would it?
okie6801 is offline   Reply With Quote
Old 11-20-2015, 10:32 PM   #2
cooperhw
cooperhw's Avatar
Re: Stock windshield tougher than new aftermarket?
yes.They are not as durable as Originals. Your original is 47 years old. You see what replacements look like in late model daily drivers? Guarantee a new one will look stunning and new but not 4 decades from now.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 11-20-2015, 10:35 PM   #3
davischevy
davischevy's Avatar
I have replaced several and I haven't broken one yet.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 11-20-2015, 11:28 PM   #4
kcsa75
kcsa75's Avatar
Go to any good glass shop and you should be fine.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 11-20-2015, 11:46 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I have installed 6 or 7 of the aftermarket windshields with no problems. The first one being in '04 and the last one last summer in the '67 Panel Truck. I had one that had a small spot in it that looked distorted but it was toward the top in the center. The only time I noticed it was when I was looking up towards the mirror.
LockDoc
Leon
Old 11-21-2015, 12:47 AM   #6
truckster
truckster's Avatar
I speak from experience, as I owned a glass shop for years. In the late 1970s manufacturers began to reduce the thickness of glass as a means of reducing weight and thereby improving fuel mileage. Look at the thickness of your door glass on your truck and compare it to the door glass on a newer vehicle. The same thing happened with the windshield. The difference is that the door glass is tempered glass, so it is very resistant to impacts. The windshield is laminated glass, which is made of two pieces of float glass (the type of glass in your house windows) laminated together with a plastic layer between them.
Since the glass is thinner, it will break more easily than the stock windshields did. It used to be you could get original-thickness glass from PPG, but I don't know if that's true anymore.
truckster is offline   Reply With Quote
Old 11-21-2015, 10:55 AM   #7
I wouldn't know since I don't go around breaking windshields . I do know there are replacement quality windshields and there are restoration quality windshields. The cheap ones are not as thick as OEM and will not seal well
Old 11-21-2015, 03:14 PM   #8
davepl
davepl's Avatar
The biggest hurdle I've seen are the seals. Search the site well before replacing your own windshield. Even the high end shop I used broke 2 until they found the right brand of seal, which sadly I forget, but it's been discussed at length here.
Still finding little pieces now and then.... always will, I bet.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-21-2015, 06:38 PM   #9
Precision seals
