Old 11-20-2015, 11:56 PM   #1
42_NATO
1965 door lock
Okay all I thought this was going to be simple but I'm not seeing anything on the web . I'm trying to replace the lock on my truck so I can lock it. Haven't had time to check the truck since its out on the farm. But when I search for the replacement lock they don't look the same. Lmc has the set of outside handle but doesn't sell the push button locks. Can any one help me out what am I not seeing
42_NATO is offline   Reply With Quote
Old 11-21-2015, 12:09 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 1965 door lock
maybe check this thread out- you might not have to replace the lock-
http://67-72chevytrucks.com/vboard/s...d.php?t=630654
Old 11-21-2015, 12:18 AM   #3
42_NATO
Re: 1965 door lock
Not sure y but my phone wont let me search here on tge forum. And google wasnt getting me anywere. Thanks so much this solves my problem
Old 11-21-2015, 12:27 AM   #4
Lugnutz65
Lugnutz65's Avatar
Re: 1965 door lock
Truck and Car Shop sells push button locks individually and in pairs.
Here is the link. http://www.truckandcarshop.com/trucks60_72/t60_020.html
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 11-21-2015, 12:44 AM   #5
pestwagon
Re: 1965 door lock
the aftermarket locks absolutely SUCK. I would recommend a set of original door locks...they pop up on e bay, aftermarket door locks are cheaply made. Broke my $99 set of locks after 1 year od daily driver use. Bought used GM door handles with original locks and key on E bay for 45 dollars....never have had a problem since AND they work like they should.
pestwagon is offline   Reply With Quote
Old 11-21-2015, 08:01 AM   #6
42_NATO
Re: 1965 door lock
Im going to take it out today and see if i can rekey it to match the ignition switch. Bt messing with tumbler. Aswell as getting a second one for my passenger side door. Just want to thank everyone for the help finding the info.
Old 11-21-2015, 05:00 PM   #7
PGSigns
PGSigns's Avatar
Re: 1965 door lock
Locdoc here on the board can do the rekey for you. Finding original ones with out the keys and having a lock smith redo them to match you ignition may be the easiest way to go.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-22-2015, 05:31 PM   #8
42_NATO
Re: 1965 door lock
Old 11-22-2015, 05:38 PM   #9
42_NATO
Re: 1965 door lock
So I took the door apart to get to the handle wish I would have taken more pics of the tear down but I managed to take apart the lock and got to the tumblers. In the first pick u can see the spring clip if for some reason thats not seated your key will not work even if its the correct one. So after pulling the retaining clip all 6 springs and tapping the tumblers out I started with one, placed it in a spot and checked to see if it worked. After trial and error and about 20 minutes I managed to get 5 of 6 to work well . for some reason the last one just didn't want to work and I wasn't going to re arrange them all 5 of 6 is good enough. My passenger door has a lock so I will be taking it apart next week.
