11-22-2015, 11:15 PM | #1 |
Wheel/Control Arm Clearance Question
Are there any known clearance issues using:
cpp 2" drop spindles stock control arms Disc brake conversion with 15" wheels 1.5" or 2" drop coil springs Wanting to use stock steel wheels if possible, knowing I may have to change to the later 5 lug wheel for brake clearance. Especially want to rule out any clearance problems with this set-up before proceeding with stock control arm paint and rebuild. |
11-23-2015, 10:40 PM | #2 |
Re: Wheel/Control Arm Clearance Question
I ran a set of the 2.5" drop spindles on stock 15" 1965 wheels but had to run spacers to clear the cast Calipers....
11-23-2015, 11:45 PM | #3 |
It depends on the 15" wheels backspacing.
