11-26-2015, 01:03 PM | #1 |
89 Crew Body on a 76 Single Frame Help needed
Calling all gear heads, I need some help!
I'm putting a 89 Crew Cab body on a 76 single cab, long bed frame - which in essence is the same thing as a suburban frame I suppose. I thought it would be as simple as bolting the body mounts to the factory location, and then cutting the rear floor out for the body to sit lower where the frame rises, but it's not. I had to modify the middle mounts to line up with the cabs body mount location. I got them bolted up and here's how it looks. middle mounts inside cab rear sitting off about 10 inches How do I get the body to sit lower? Seems like something more is going to have to happen than "just lowering" the mounts. What am I missing here? Thanks in advance **UPDATE** I moved the he "middle mounts" down, to bring the body down, and it looks a bit better now, however the front and rear are off about 3". So the only real option I know, to fix the issue, is to drill new holes for the front mount, and move the cross member in the rear, to get them to line up. I was hoping, someone else that has done this job, could shed some real details/light on the over all process, before I go crazy and mess something up!! |
11-26-2015, 02:20 PM | #2 |
Re: 89 Crew Body on a 76 Single Frame Help needed
This guy did it: http://67-72chevytrucks.com/vboard/s...=582618&page=2
its missing a lot of pics now but you can read and see some of the frame and cab pics on page two.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
11-29-2015, 08:25 AM | #3 | |
It seems it is going to need quite a lot of work to get it sitting right.. I don't think there is any way to use the factory locations for the cab mounts. |
