#326 |
Re: 53 Surburban "Family Truckster"
I've enjoyed catching up on your build so far. I did something very similar for my '71 C10, in stealing the drive train out of my '98 T/A. Had enough $ sunk in between having the LS1 built to a fully balanced forged 383 and the 4L60 built to support it that I knew I'd never get it back if I sold the car as it sat, so I cannibalized the car to support the truck build and sold off the scraps. Will we kick ourselves in 20 years for doing this to otherwise decent f-bodies? Who knows, I kind of kick myself every time I see a red 4th gen bird roll by with the t-tops off already, but at least there are still clean ones out there to be had cheap.
Keep up the good work. |
#327 |
![]() Join Date: Jul 2012
Hat's off to you Marc! We took the easy way out...lift and 4 guys. OK, three of us bench raced while one did most of the work.
#328 | |
![]() Join Date: Mar 2007
Marc
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#329 | |
Thanks for following along. Marc
#330 | |
Thanks man Marc
#331 |
Well I spent more money today...Does that count for progress because if it does I have been busy as of late. I got a smokin deal on an Accuair set up. It is new and still factory sealed and has never been installed. I have always planned to run Accuair for air management but I didn't plan to buy it for a while. This is the most current kit with the newer ride height sensors.
Local score so no shipping costs either...... Marc
#332 |
nice score, you get a manifold?
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#333 |
Very nice! You must be a Craigs list Ninja....
#334 |
No I will need to pick one up. This was too good of a deal to pass up on. I will pick one up later a long with 2 compressors and a tank or two. This works ok because I can spread out the cost this way.
It was a tip from a friend. Marc
#335 |
![]() Join Date: Mar 2011
Nice looking kit...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#336 |
Nice score!! It's on my list of upgrades.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#337 |
Marc will that unit work on any airbag system? I am using the one that came with my ride-tech system.
It works and does what it is intended to do but I would like to use something else. The system I have does not self level and I know very little about what is on the market. |
#338 | |
I have my garage back from the Camaro and the frame staged. I'm looking forward to cutting into the old frame for the PB goodies. More progress pics soon...I promis. Marc
#339 |
Well I started my Porterbuilt install yesterday. I talked with Nate at PB to plan the install. He would like my feed back on this install and I committed to him to document it with a lot of pictures. I measured a bunch before making the first cut. I also tooled up with a new 1/2" drill. I'm pretty happy with the progress that I made.
I overlaid the frame rail to mark the locator holes. the front does not align with any factory holes. Scary at first but once Nate explained how to positon the drop member to find my location it made perfect sense. I cut my frame using a cutting wheel on my electric grinder and I was surprised at how easy it cut the fame.
#340 |
Continued...
I separated the OE front section and set it aside while I drilled the remainder of the holes to mount the PB front section. I then reassembled the DM. My first impression of the installation is it is like a big lego set. I'm very pleased More pics
#341 |
Nice work and explanation Marc. Is this the first PB member going in on an AD frame?
#342 |
First off let me say I love the burb! Looks like we have both been waiting a long time for these dropmembers! I almost went a different route 4.5 months ago, but Nate/Dave confirmed with an e-mail the day after saying they were taking preorders. Anyways, after seeing your build come together I'm really glad I waited. Nate confirmed my parts will be shipping next week and I sent him a message about wheel specs, but have not heard back (holiday time). Just curious if you know backspacing and wheel height specs? Sorry for the long post!
#343 | |
Marc
#344 | |
Good luck..Oh and it is worth the wait. Marc
#345 |
Now onto the rear. Once you have located the locator hole in the front, you use this same hole and measure back to locate the placement of the rear notch...I confirmed one of my initial concerns. The rear body mounts interfere with the rear notch. I removed the mounts for now. They will be easy to reattach. Since this is a suburban that I'm building I bet PB didn't realize this would be an issue since they mocked up to truck frames. This is something that I took pictures of and I will be communicating back to them.
I cleaned both frame rails with a wire wheel, to make slipping on the rear rails easier. I later determined that I need to clearance the frame for the welded nuts on the inside of the notch. More thought/planning is needed here. I will figure it out. Again. I'm like the challenge of figuring this out. Marc
#346 |
Detail of the body mount removed and the and rear notch...
That's a wrap for the night... Marc
#347 |
Yes I did and thanks! I thought it would be better to ask over here. I was really looking for max tire diameter and wheel backspacing. I will be running 20's front and rear also. 22's are nice to look at, but I'm going to drive the **** out of this truck and want the best ride! I think Dave told me the front backspacing can not be more that 5.25 or front tire will make contact with sway bar. Anyway, sorry to be asking so many questions and look forward to your build!
#348 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Dang!!!! Lookin good.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#349 |
Looking really good Marc!
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#350 |
**** yea. This is wicked. Love the PB stuff.
