Old 12-02-2015, 10:19 AM   #301
reaper71
reaper71's Avatar
Re: Blake's 67 GMC stepside build
Thank's Kees, I think it's a mixture between really Brave or really Stupid!
reaper71 is offline   Reply With Quote
Old 12-02-2015, 10:28 AM   #302
reaper71
reaper71's Avatar
Pic #1. The new piece after making the needed bends.
Pic #2. Mocking up the fit.
Pic #3. Another view.
Pic #4. This was after the welding,metal finish and some weld through primer were done and the O.E. mount welded back in.
Onto the passenger side.
Mark...
Old 12-02-2015, 01:54 PM   #303
Advanced Design
Advanced Design's Avatar
Nice work Mark. I am thinking I would have thrown in the towel on that one.
Advanced Design is offline   Reply With Quote
Old 12-03-2015, 10:55 AM   #304
reaper71
reaper71's Avatar
Thank's Doug!
It was kinda like the seen from "Fastimes at Ridgemont High" when spicoli says "I've got an awesome set of tools I can fix it!"
So I took a leap into the deep end!
Mark...
Old 12-03-2015, 11:06 AM   #305
reaper71
reaper71's Avatar
Pic #1. This was the mock up of the large section for the passenger side.
Pic #2. After it was tacked in place.
Pic #3. 2nd view of it tacked in place. If you notice it has holes in it for flange nuts to be welded in for mounting the inner fender.
Pic #4. In this shot it shows the upright all repaired just like the Drivers side.
Moving on...next up flange nuts and flange.
Mark...
Old 12-03-2015, 04:27 PM   #306
RockinKees
RockinKees's Avatar
None of that.
You are Supernatural
Really nice work, Doug is right I think, most of us wouldn't start on this one!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-04-2015, 10:29 AM   #307
reaper71
reaper71's Avatar
Well I don't know about the Supernatural thing but thank's for the compliment my friend (your skills are right with me)
Old 12-04-2015, 10:45 AM   #308
reaper71
reaper71's Avatar
Pic #1. Flange nuts welded in place, ready to start on the flange.
Pic #2. The flange was super easy, I just cut a long strip and started tacking along the length and bent to shape. Weld,grind etc.
Pic #3. 2nd view
Pic #4. 3rd view for good measure.
Mark...
Old 12-04-2015, 11:29 AM   #309
reaper71
reaper71's Avatar
Btw I am starting a new build thread for another customer (off topic in alternate tinkering ) on a 1978 Toyota FJ40
link down below.
http://67-72chevytrucks.com/vboard/showthread.php?t=690527 Reed 78 FJ40 Rebuild
Old 12-04-2015, 02:42 PM   #310
Advanced Design
Thank's Doug!
Mark...
I think it is way more than an awesome set of tools....
Old 12-07-2015, 10:40 AM   #311
reaper71
reaper71's Avatar
HaHa Thank's Doug!!
Old 12-07-2015, 11:07 AM   #312
reaper71
reaper71's Avatar
Pic #1. The upper portion of the stock core support is very Ugly with these relief cuts, SO away they will go...
Pic #2. another view (do not have a after shot) But they were welded,ground and metal finished smooth!
Pic #3. This was after some light bodywork,Epoxy primer and High Build primer.
Pic #4. 2nd coat of H.B. Primer
Old 12-08-2015, 10:43 AM   #313
reaper71
reaper71's Avatar
Pic #1. The core support is all done and in it's final paint, again going with the Satin black.
Pic #2. another view.
Pic #3. Set in place with the inner fenders.
Just to recap on the Engine bay: Firewall,under hood, inner fenders and core support will All be Satin Black. Trying to give it a little contrast when you open the Hood. Have not nailed down what all will be done with the Engine yet will figure it out as it progresses.
Mark...
Old 12-08-2015, 05:42 PM   #314
RockinKees
RockinKees's Avatar
Came out great!!
Really a nice job you did there!!
Cheers!! Kees.
Kool Guyz CC
Old 12-08-2015, 09:23 PM   #315
yj4000
yj4000's Avatar
Yea!! Nice job. I like the idea of satin.
Ryan.
yj4000 is offline   Reply With Quote
Old 12-09-2015, 10:22 AM   #316
knomadd
knomadd's Avatar
You've done a lot of nice metal work on this. I'll be following along. Keep it up!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 12-09-2015, 10:54 AM   #317
reaper71
reaper71's Avatar
Kees,yj4000,and knomadd thank you guy's!
This thing has been a TON of work,more than I had ever expected it to be but I guess that's all part of it! (it was an old Farm truck and it shows!!)
Mark...
Old 12-09-2015, 11:05 AM   #318
reaper71
reaper71's Avatar
So now that the core is finished I will turn my attention to the inside of the cab again. This time the inner roof. The customer is a Big guy and can't use the sun visors so the stock holes will be filled per his request.
Pic #1. Here I'm getting ready to weld up several holes that someone screwed fabric to the back panel years ago.
Pic #2. Visor holes welded up.
Pic #3. 2nd view.
Pic #4. (jumping ahead after bodywork) Sprayed in Epoxy Primer.
Pic #5. And finally in H.B. Primer and ready for blocking.
Mark...
Old 12-10-2015, 11:02 AM   #319
reaper71
reaper71's Avatar
Pic #1. The cab all masked and ready for interior color.
Pic #2. 2nd view.
Pic #3. After the color was shot. (it is a G.M. color called light shale)
Pic #4. 2nd view.
up next is the roll pan it will need a bit of fine tuning.
Mark...
Old 12-11-2015, 12:46 AM   #320
swamp rat
swamp rat's Avatar
Doing some nice work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-11-2015, 06:30 AM   #321
Advanced Design
Yep, nice work Mark. The light shale...was that an original color? It kinda looks like primer and I don't remember seeing it before.
Old 12-11-2015, 10:53 AM   #322
reaper71
reaper71's Avatar
Thank's Swamp rat
Old 12-11-2015, 10:58 AM   #323
reaper71
reaper71's Avatar
Thank's Doug!
Yes it is a stock GM color and they have a medium and Dark as well.
On his interior there will be some dark accent pieces to mix it up a bit.
It was an early 2000 model I believe.
Old 12-15-2015, 11:05 AM   #324
reaper71
reaper71's Avatar
I'm going to switch gears a bit here and show the roll pan.
Pic #1. When the pan showed up it wasn't the best looking piece..meaning seams not welded ugly corners etc. So in this shot I welded the seams around the plate box and the ends.
Pic #2. I then rounded the corners and will cap them off. (bolt on pan)
Pic #3. The mockup piece for the cap. These will add a more finished look to the ends of the pan when mounted.
Pic #4. After welding.
Pic #5. In Epoxy primer.
Mark...
Old 12-16-2015, 11:35 AM   #325
reaper71
reaper71's Avatar
Pic #1. The Drivers door being prepped for interior color. The top section of the door will be the same as main color of the truck.
Pic #2. After laying down the blue Fine Line tape.
Pic #3. Another view of how the separation of the colors will be.
Pic #4. After Light shale was shot.
Mark...
