Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 12-03-2015, 08:45 AM   #401
msgross
msgross's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
I was told my an old truck guy that truck tolerance on the assembly line was 1/4" so anything closer than that is a win. These weren't built for show trucks, no car was back then anyways.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-05-2015, 12:42 AM   #402
First c10
First c10's Avatar
Okay so this is my first time replacing a cab corner. I must have put it and the rocker on 100 times.... So I just decided time to weld.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-05-2015, 12:49 AM   #403
First c10
First c10's Avatar
Ok so I was having a hard time welding the cab corner where 2 layers of metal were. I am thinking contamination from whatever was between the layers of metal. Because the exposed metal was epoxy primed which I sanded off. But something was causing an issue.
I will try and get it finished welded up on Saturday.
GO GO!!!
Old 12-13-2015, 12:19 PM   #404
7dee2
7dee2's Avatar
Looking good sir! Did you get past the contamination problem?
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 12-15-2015, 12:42 AM   #405
First c10
First c10's Avatar
Thanks and Yes just had to clean out the caulking the PO put on from underneath.
I had my bodyguy friend stop by when I had the rocker and door set. He said it looks better than original as far as the gaps. So since I didn't know how good was good I was afraid to just weld it. After he told me that I thought time to burn it in.
This is a picture of the inner rocker with rust encapsulate on it.
GO GO!!!
Old 12-15-2015, 12:44 AM   #406
First c10
First c10's Avatar
This is the out rocker primed. I painted it before I installed it
GO GO!!!
Old 12-15-2015, 12:45 AM   #407
First c10
First c10's Avatar
This is the rocker burnt in.
GO GO!!!
Old 12-15-2015, 12:47 AM   #408
First c10
First c10's Avatar
Close up of the driver rear door jab rocker.
GO GO!!!
Old 12-15-2015, 11:19 AM   #409
7dee2
7dee2's Avatar
Good job!
Brett
Old 12-15-2015, 11:22 AM   #410
DWilbur
Looking real good. If you have time could you weld in the 16 seat nuts for me. I'm not looking forward to this step welding upside down.
DWilbur is offline   Reply With Quote
Old 12-16-2015, 12:16 PM   #411
First c10
First c10's Avatar
Good job!
Thanks Brett.
Thanks David your truck is looking great also... welding upside down get out the TIG!!!
GO GO!!!
Old 12-17-2015, 12:55 AM   #412
First c10
First c10's Avatar
hey guys I have a question regarding the holes in the firewall.i want to weld up the ones I don't need but not sure what all of them go to.
This picture is of the original throttle area and I think the top holes are for the windshield washer hoses. What did you guys do?
GO GO!!!
Old 12-17-2015, 01:01 AM   #413
First c10
First c10's Avatar
Does anyone have a picture or something about what each hole is for? Some I can figure out some not sure about.
GO GO!!!
Old 12-17-2015, 07:54 AM   #414
CUSTOM/10
CUSTOM/10's Avatar
This picture might help !
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 12-17-2015, 11:13 AM   #415
7dee2
7dee2's Avatar
Here is another and one for A/C & non A/C. The extra hole not marked between the fuse block and the emergency brake I believe is for a tach harness.
Brett
Old 12-17-2015, 11:38 AM   #416
First c10
First c10's Avatar
Thank you Gary. I noticed that your cab is a little different than mine. Mine is a pre 71 I think as my cab did not have the throttle cable but the throttle pivot rod.
Can anyone tell me if I need the holes with the black arrows?
GO GO!!!
Old 12-17-2015, 11:48 AM   #417
DWilbur
I filled in most of the holes on my fire wall. for the AC I cut out a bigger hole and did 1 patch panel. the smaller one I use a hole saw to make plug and welded them up.
Old 12-17-2015, 12:00 PM   #418
First c10
First c10's Avatar
That's exactly what plan to do with the holes... I just don't want to fill in holes I will have to re-drill at a later date.
Do you have a picture of your firewall??
GO GO!!!
Old 12-17-2015, 12:11 PM   #419
First c10
First c10's Avatar
Thanks Brett. I didn't scroll up so I didn't see this post.
I will study it..
Thank you!
GO GO!!!
Old 12-17-2015, 01:18 PM   #420
CUSTOM/10
CUSTOM/10's Avatar
3 of the holes are for the rubber plugs that hold the jute to the inside of the firewall, and the hole next to the steering column opening is for the collar that hold the column boot on. ( Screw hole )
Gary
72 SWB 4x4
My 72 SWB Build
Old 12-17-2015, 02:09 PM   #421
DWilbur
I don't have any picture now I can get you some tonight
Old 12-18-2015, 12:44 AM   #422
72MARIO
72MARIO's Avatar
I ran my washer hoses thru the cowel from inside the cab rather than out the fire wall and over the rain gutter.I brought the feed tube in below the parking brake cable. Much cleaner
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-18-2015, 12:46 AM   #423
72MARIO
72MARIO's Avatar
For the hole with the black arrows i welded a 1" long piece of threaded rod in place of the screw and used nuts inside to hold the coloum dust boot in place
2005 TAHOE DD
Old 12-18-2015, 11:57 AM   #424
First c10
First c10's Avatar
Can I weld up the holes and install studs to mount the jute with washers and nuts like you said about the column seal?
GO GO!!!
Old 12-24-2015, 12:55 PM   #425
7dee2
7dee2's Avatar
You could or don't bother with the padding at all you could use a stick on or spray on sound deadener perhaps?
Brett
