Old 12-03-2015, 12:18 PM   #1
gmachinz
406 powered S-10
Yeah I know...this has been done to death but I'm attempting a factory appearing SB install.....only have this pic for now....I built a custom harness conversion just for this truck-heres a teaser pic.....
gmachinz is offline   Reply With Quote
Old 12-03-2015, 11:51 PM   #2
jmking9
jmking9's Avatar
Re: 406 powered S-10
Looks great!
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 12-05-2015, 12:47 PM   #3
Zane M
Looks great!
Hopefully you can show us some more, and any tips and tricks you utilized.
Zane M is offline   Reply With Quote
Old 12-05-2015, 01:23 PM   #4
gmachinz
One thing that was odd was that the Hedman conversion headers had the exhaust flanges welded on upside-down. I didn't notice it until I went to try and thread the OEM temp sensor into the cylinder head and the edge of the header flange wouldn't allow for it. So I relocated the sensor to the intake. The 2 electric fan temp switches are mounted in the aluminum t-stat housing.
Old 12-08-2015, 11:01 PM   #5
gmachinz
Closeup of the charging system harness and the low/high temp trigger leads for the dual speed/dual fan assembly I'm adding.
Old 12-08-2015, 11:08 PM   #6
gmachinz
More pics....AC delete panel is used on this truck but I'm still retaining the original AC harness. PO hacked it all stupid so I put it back correctly and mounted an AC blower resistor. Other pics show the electric fan temp switches, and I added a couple extra IGN hot leads from the modified factory fuseblock bulkhead connector so I can add a simple plug in for the electric fan relay bank IGN on trigger.
Old 12-08-2015, 11:09 PM   #7
gmachinz
Extra IGN on pigtail....
Old 12-13-2015, 11:20 AM   #8
gmachinz
Working on adding the dual fans....its easy to get sidetracked! Lol I'm using a GM style serpentine bracket setup w/long style water pump and the water pump snout-electric fan clearance is a tad close on clearance. So, I'm carefully notching the core support to give my another 1/4" so I can have at least 1/2" of clearance. There isn't much to this core support up top so after the radiator install I'll be making an "X" brace to strengthen it back up.
Old 01-22-2016, 12:38 AM   #9
gmachinz
Well, tonight I tinkered with the S-10 for a bit. I had to remove the dash to access a center firewall grommet so that I could extend my ignition control harness like factory instead of drilling an extra hole. Then, I figured I might as well change the heater core-then the snowball started.....I noticed the ductwork seals were shot so I started making new foam seals-then while taking the ducting all apart, I seen the upper/lower dash blend door linkage was broken;this is awesome since finding a replacement will require completely dismantling another trucks' dash!
Old 01-22-2016, 12:45 AM   #10
gmachinz
Factory style harness with aftermarket integrations, pics show the close but manageable space between the Chrysler dual fans and the GM style serpentine setup. I also opted for the Goodyear severe duty heater hoses. Tonight I built a pair of 3/8" radiator cross braces since notching the core support for the larger radiator made it slightly flimsy vs stock.
