12-05-2015, 02:01 AM | #26 | |
Moderator
Re: 74 k5 cheyenne blazer
The starter is really a very simple circuit. What is she doing when she won't start? Not cranking? OR. Cranks but she won't kick over?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
12-05-2015, 12:43 PM | #27 | |
Moderator
You have a bad connection between the starter and the battery. Either you aren't getting a reliable ground or you aren't getting a reliable hot connection to the starter... or both. Since you replaced the hot cable I'll assume it's OK. On a vehicle this old the main battery cables are suspect at best. You replaced the Hot cable from the battery to the starter. Did you do the ground cable? Is the ground attached to the stock location on the alternator bracket? Clean up the battery ground cable connection on the alternator bracket and re-install with star washers and never seize. Clean up both of the alternator bracket to engine bracket bolts and re-install with Never Seize. This is for the P series with The L05 TBI engine. It's very close to the CK trucks. Rotate the battery 90° and you have a CK series V8. Engine ground is G111 body ground is G110. A distant third would be the Start impulse wire from the ignition switch to the 8-32 "S" stud on the starter. Usually this is a purple wire but not always. It's real easy to clean this one up... . . .
05-26-2016, 06:27 PM | #28 | |
