Old 02-25-2004, 11:42 AM   #1
Erl
Erl's Avatar
Spreader for a Dana 60
I am getting ready to change the Dana 60 ring and pinion from 4:56 to 3:73 in my truck. The service manual shows a spreading device to deflect the differential housing enough to remove the carrier. Is this spreader necessary? If so, can it be rented? Or should I just make one?
Erl
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 02-25-2004, 12:24 PM   #2
Rod
The things are in there fairly tight but they come out... I've done it in scrap yards while under the truck on my back, no speader apparatus involved..
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-26-2004, 02:24 AM   #3
Mike C
Mike C's Avatar
YOu can do it without the spreader. The newer 60's don't specify that you need it. Not sure if they have less bearing preload than the older ones. The spreader is NOT cheap. Randy's Ring & Pinion sells spreaders. About $250 so you'd have to use it more than once... I am going to buy one when I do the Trac Lok in my 60. I have 3 60's and two trucks that I will go through diff on. That will make it worthwhile IMO, plus I can pick up another one to do for $ at a later date I would guess.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-26-2004, 11:40 AM   #4
Erl
Erl's Avatar
Randy's ring and pinion plus my 68 GM overhaul manual say it is necessary to get the proper preload on the carrier bearings. Randy states that a major factor in many rear end failures is improper bearing preload. I am going to make one myself. I will post some pictures of it in action. If it works well I will loan it out to board members.
Erl
Dallas TX
