Old 12-12-2015, 01:37 AM   #1
Rod Run
Rod Run's Avatar
5" & 7" drop with 17" wheels picture help
Hoping for a little picture help here.
I'm looking to put 17x8 front wheels on my truck with 4 1/2 backspacing
17x9 with 5" backspacing in the rear
I have a 71 step side, so I was wondering if anyone has pics of 17" wheels on their ride with that drop? If you do, could you please list your tire sizes also?
Even is you don't have a step side and have that set up, I would appreciate those pictures too, because it will still show me how the tire height is in relationship to the opening and I can see how much it fills the wheel wells.
thanks in advance for any help
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 12-12-2015, 12:38 PM   #2
XwalkerX
Re: 5" & 7" drop with 17" wheels picture help
im interested to see this as well.
ive got a 4.5 front and 5 rear drop that ive been wanting to sell my 18's and put some 17x8/17x10 wheels with taller tires on.
XwalkerX is offline   Reply With Quote
Old 12-12-2015, 12:51 PM   #3
Mrturner1
hopefully you get lots of pics, but if not, search 5-7 drop pics and you can cruise about 10 pages FULL of awesome trucks with that exact kit
Mrturner1 is offline   Reply With Quote
Old 12-12-2015, 05:54 PM   #4
Rod Run
Rod Run's Avatar
Thanks for the advice, but I already tried that route. I've tried that search and "17" wheels and ended up spending multiple hours, only to find about three or four 67-72 trucks with 17" wheels and some sort of drop and from that there was only about 2 with tire sizes.
I even searched the 3-5 drop thread and that didn't really help either. Actually, now that I think of it, that was the thread where I found that previous info
Old 12-12-2015, 06:33 PM   #5
Fastfun
Fastfun's Avatar
The closest that I have is 17x8 and 17x10 with a 3" front drop and a 5" rear
Fastfun is offline   Reply With Quote
Old 12-12-2015, 07:32 PM   #6
Rod Run
Rod Run's Avatar
Tire sizes?
Old 12-12-2015, 10:34 PM   #7
sierragrande71
sierragrande71's Avatar
I have a 5 inch drop on my gmc, i no longer own the 17inch ansens that were in it. But it gives you an idea what it could look like.
sierragrande71 is offline   Reply With Quote
Old 12-12-2015, 10:35 PM   #8
sierragrande71
The wheels were mounted on Hankooks P255/50R-17 on all four corners.
Old 12-12-2015, 11:01 PM   #9
Rod Run
Rod Run's Avatar
Thanks so much. Those look like they did a decent job of filling the wheel well, without having excessive sidewall height.
I am worried about needing to tall a tire, with the 17" wheel. I don't like to see a lot of sidewall. I'm ok with what is needed for fitment on cars, but not so much with trucks.
Old 12-12-2015, 11:13 PM   #10
Mike C
Mike C's Avatar
I have that combo on my truck, a '69 short step. At least really close. 2 1/2" spindle and 2" spring in the front for 4 1/2" drop. Rear is a leaf spring flip from JDM using a '72 5 lug housing for a 7" drop.
Summit legend wheels in the front, 17x8 with 4 1/2" bs and 235 55 17 and 17x9 rear with 5" bs and 275 55 17. At least on my truck, that's the biggest tire that will fit.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-12-2015, 11:21 PM   #11
sierragrande71
No problem rod run, i have since gone back to the stock steel wheels with wheel covers
Old 12-12-2015, 11:40 PM   #12
Rod Run
Rod Run's Avatar
I like your front sizing also. That looks like you fit plenty of tire in back
I like a staggered fitment too, but I personally like to keep my front & rear tires the same height. Are your rears taller, or is it just the shadowing?
Thanks so much!
Old 12-13-2015, 10:44 AM   #13
Mike C
Mike C's Avatar
I wanted a little rake to the front and a tall tire in the rear. The front 23 55 17 are 27" tall and the rear 255 55 17 are 29". My opinion again, but this is a near ideal tire size for the trucks to fill up the wheel well and maximize driveability.
I have no rubbbing with this combo and usually no issues with frame in the rear. A big sharp hit at speed will contact the bumpstops on the frame. I cut the factory pads off the rear axle and the DJM kit came with new urethane pads with a single 1/4" bolt that you mounted to the frame over the axle housing. Any more drop in the rear would require a c-notch FWIW.
Shot from the rear 1/4:
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-13-2015, 02:27 PM   #14
Rod Run
Rod Run's Avatar
That shot really shows how good everything fits.
I already notched my frame, so I don't have to worry about hitting. I'm not usually big on different height tires, but that picture might have changed my mind a bit. Again, thank you for the pictures. They really do help a lot
Old 12-13-2015, 02:29 PM   #15
Mike C
Mike C's Avatar
No problem. Looking forward to seeing what you decide on.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-14-2015, 08:49 PM   #16
68Stepbed
68Stepbed's Avatar
4.5/6.75 with 17's
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-14-2015, 09:31 PM   #17
Rod Run
Rod Run's Avatar
Originally Posted by 68Stepbed View Post
4.5/6.75 with 17's
Tire sizes?
Old 12-14-2015, 09:42 PM   #18
jessemthompson
255/50/17s up front 275/50/17s out back 4.5-6" drop
jessemthompson is offline   Reply With Quote
Old 12-14-2015, 09:52 PM   #19
Rod Run
Rod Run's Avatar
Thanks.
You guys are giving me (and hopefully others) a great database for different tire options, when it comes time to pull the trigger.
I can say that I definitely feel confident in buying 17" wheels after seeing these pics. Now I've just got to look closely at the tire sizes and make up my mind. I hope to be buying the tires after the new year
Old 12-14-2015, 10:09 PM   #20
68Stepbed
68Stepbed's Avatar
Tire sizes?
Hankook Ventus ST 255/50/17 front 275/55/17 rear. I can no longer find the rear size in a matching set. The only tire options you'll find for 17" tires is the Nitto NT450 in 275/50/17 rear 255/50/17 front. I'll most likely switch to 18's soon for better tire options.
Matt
Old 12-14-2015, 10:39 PM   #21
Rod Run
Rod Run's Avatar
You have any problems with rubbing in the rear, or you have room to spare?
Old 12-15-2015, 08:45 AM   #22
68Stepbed
68Stepbed's Avatar
It only rubs under hard cornering. Of course, since I autocross it and aggressively drive back roads, it's starting to blister the paint on the inner bedsides. lol A good sway bar and some chassis stiffening would fix most of that.
Matt
Old 12-15-2015, 12:32 PM   #23
Rod Run
Rod Run's Avatar
thanks for the info.
I can't believe how hard it is to find tires in these sizes. It almost forces you to go up to 18" diameter, but that definitely kills the "budget build" type of thing
Old 12-15-2015, 01:32 PM   #24
KY_GMC
KY_GMC's Avatar
Here is mine with 4" drop in the front and 6" or so in the rear (did a leaf spring flip kit so the actual drop may be closer to 7").
255/60/17 in the front and 275/60/17 in the rear. The front tires are close to hitting the wheel well on the left side, but I'm dealing with a bent frame right now and I think that is contributing to that.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 12-22-2015, 08:21 PM   #25
Sixteen Tons
Sixteen Tons's Avatar
What wheels are you running man? Have never seen that particular style, kinda digging it.
Wanda - 1969 C/10 LWB 250 I6 3OTT
LWB>SWB
Sixteen Tons is offline   Reply With Quote
