12-11-2015, 09:10 PM | #551 |
6>8 Plugless........
Re: 71 4X4 Frame off Restoration
Awesome! An early Christmas to ya! Sort of.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-12-2015, 07:08 PM | #552 |
I picked up my cab today an early Christmas present. My nephew stopped by and helped me set it on the frame. Had to pull the bed off then set the cab on then put the bed back on. it just fit in the garage door with 1" to clear. It looks like the T-case shift levers will fit with out any modification. Got lucky there. This is the first time the cab has been on the frame with the running gear installed. Next step fit the seat, 2004 steering column, break and clutch peddles.
12-12-2015, 07:25 PM | #553 |
SWB 4x4 Collector
Looks good! Got to be a great feeling!
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
12-13-2015, 03:52 AM | #554 | |
Gotta feel good getting the cab on that frame!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-13-2015, 12:11 PM | #555 |
Looks really good! That is a tight fit in the garage!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
12-13-2015, 03:39 PM | #556 |
Well Congrats!!! Huge milestone. If I remember correctly, it went a lot faster once I started getting body parts back on the frame to finish mock-up.
Keep at it and good luck. Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
12-13-2015, 10:55 PM | #557 |
Thanks guys. I have a set of 36" tires for the truck.
12-16-2015, 05:38 PM | #558 |
That looks awesome!
01-04-2016, 01:56 AM | #559 |
Just read the whole build, awesome
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank. 70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank Dads: 67 c10 step side(project) 72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter) Ours: 67 c30 tow truck 70 c10 long bed 383stroker w/digital gauges(work truck) |
01-04-2016, 01:32 PM | #560 |
Hello twistedchevy
Thanks for spending the time reading my thread. |
01-22-2016, 11:16 AM | #561 |
Awfully quiet over here??? lol
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
01-22-2016, 01:19 PM | #562 |
Hello First C10
It's been raining here in California at least in my area most week ends and I can't work on the truck in my garage no room to move around. I have to move my truck out side to do anything. I did buy electric fan set up last week and Monday was a holiday so I was able to drop off some part at my powder coater. |
01-22-2016, 01:29 PM | #563 |
I totally understand that's a big truck and that garage. Yeah it's been raining a lot on the side of the hill also. I just thought I check in on you see how you were doing. I'm going to be Ordering my vintage air so I can get the holes and any mounting brackets added to the cab before I send it off to get the body work done. Glad to hear you're getting some stuff done.
01-22-2016, 03:45 PM | #564 |
I have my cab set up for the Vintage Air kit. you have to cut 2 round holes and 1 square hole in the dash for the vents. the kit comes with a plate to cover the heater box hole. I welded up the heater box holes on my cab. The coil that goes in front of the radiator fit like factory one for me. I added a second grommet for the lines that go through the core support. you can get an extra grommet from any of the suppliers for the factory set up works good. I also got the factory bracket to support the line under the battery box.
01-22-2016, 03:55 PM | #565 |
How did you mount the evaporator and fan assembly on the inside?
01-22-2016, 07:18 PM | #566 |
awesome build, can't wait to see more!
02-01-2016, 02:50 PM | #567 |
I worked on getting the wiring harness out of my 2004 Suburban I bought about year ago. The city sent me a letter to get my trucks off the dirt by Thursday last week or they will fine me $100. So I did get 2 of them off the dirt but the Suburban is mostly gutted just need the wiring and brake parts and then I can drop it off at the wrecking yard. Ho and I did get the seat out of the Suburban and in my 71 they fit real good. just have to bolt them in place.
02-01-2016, 02:53 PM | #568 |
02-04-2016, 01:52 AM | #569 | |
Thanks Scott
02-04-2016, 12:45 PM | #570 |
I have not installed anything in the cab yet. I do know that we loose most of the glove box. The kit comes with a new glove box that is about 3" deep.
02-04-2016, 12:51 PM | #571 |
Oh ok. Was there a pattern or template to identify the location for the holes in the firewall?
02-04-2016, 01:15 PM | #572 |
Yes the kit comes with templates to drill the holes in the fire wall.
02-05-2016, 11:23 AM | #573 | |
PITbut
Nice build.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
02-05-2016, 11:33 AM | #574 |
A buddy of mine used the filler piece that vintage air sent with the kit. He said that the bolts that hold the inside piece are the ones that go through the firewall filler piece and firewall. I plan to try and install studs to the inside of the cabs firewall.
02-05-2016, 11:59 AM | #575 |
