Old 02-26-2004, 12:11 AM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
Unhappy my truck died
i was driving my truck out of the welding shop today after school(i am fabricating a hidden hitch to go behind my roll pan, i'll have pics when it is finished) and the motor started running rough and then died and it will not start. any ideas on what might cause this? i'm not going to be fixing it because it is still on warranty but the shop probably won't know until friday and was just curious about what might be going on.
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 02-26-2004, 12:12 AM   #2
bpmcgee
bpmcgee's Avatar
Could be a fuel pump or filter.
Brian
bpmcgee is offline   Reply With Quote
Old 02-26-2004, 12:15 AM   #3
jorgensensc
jorgensensc's Avatar
Sounds like a fuel problem. My truck ran identical to that the 2 times I ran out of gas (stupid fuel gage).
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 02-26-2004, 12:15 AM   #4
71chevylongbed
Got Horsepower?
the fuel pump(Holly 120gph) has only been on a few months and if it was a filter wouldn't it be running bad before because it had plenty of power when i was driving it to welding?
Old 02-26-2004, 12:21 AM   #5
71chevylongbed
Got Horsepower?
hopefully i will know by friday what the problem is
Old 02-26-2004, 03:08 AM   #6
1969 GMC
1969 GMC's Avatar
try adding gas...my truck's gauge said i had 1/8 tank left and it died right when i was traveling down a very busy 2 laned state route at dinner rush, and it ran rough for a few seconds before it quit.
oh boy, i have never seen so many middle fingers in my life.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-26-2004, 03:13 AM   #7
Hooter
My other Love
Hooter's Avatar
hmm do you have HEI those modules will crap out on ya at random times
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-26-2004, 05:06 AM   #8
Lippyp
English Chevy Owner
Lippyp's Avatar
Or if points maybe they closed up, has happened to me before with other cars.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 02-26-2004, 09:54 AM   #9
MOTHERTRUCKERS
Did they disconnect your battery cables when welding on the frame.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 02-26-2004, 11:56 PM   #10
71chevylongbed
Got Horsepower?
i got it back from the shop today and the problem turned out to be a bad fuel pump which is irritating because the bump was only a few months old but at least it is running again so i can go
Old 02-27-2004, 12:04 AM   #11
imdarren
imdarren's Avatar
Just an observation.
You said that your truck was under warranty?
So it's a newer truck?
If It is a newer truck, remember to unhook the battery when welding on the truck, or you could fry / or do some serious damage to the electronics / computers.
Maybe I'm off track here.
EDIT: Ok. I read closer. You have a 71 Chevy.
Whats under warranty? The motor?
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 02-27-2004, 12:35 AM   #12
71chevylongbed
Got Horsepower?
the truck is a '71 and i just had the motor built last summer and it has a 12 month/12000 mile warranty on it but i had to pay for the pump because it wasn't replaced when the motor was built
Old 02-27-2004, 01:20 AM   #13
71Rat
ran out of money
71Rat's Avatar
imdarren: you can weld on cars with computers, i have seen it done many of times. to me i am not sure what is better to disconnect the battery or to keep it connected. i know if you have a computer controled car and disconnect the alt. that the comp will be fried. the battery controls voltage spikes from going to the computer. i am not saying your wrong just that i have seen it done and the comp was fine..... maybe someone has strong evidance on what way is the best
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 02-27-2004, 01:57 AM   #14
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
I would disconnect the battery when welding on any vehicle! JMO, but I've done it on both computer controlled and non-computer controlled. I feel it safer to do it. Welding, as we know, takes a lot of current. And the more resistance you have (air), the higher the voltage needs to be to make the same amount of current. So the voltage is high. Even though current takes the path of least resistance (it going straight to your ground) I would still be afraid of a little bit going somewhere else on the frame of my truck, to something that I don't want to get voltage.
71Rat, what do you do when the alt goes bad?! Do you mean while the vehicle is running?
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
