Old 12-18-2015, 11:55 AM   #101
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
I can see the light!
This is a household light socket that the po put in. I put a 12 volt bulb in it and it works!
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 12-18-2015, 04:19 PM   #102
rusty76
rusty76's Avatar
That's so cool. Years ago I used to use a five watt bulb in household socket hooked to my CB radio. It would light up when you talk or modulate. Really neat way of testing the radio.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-20-2015, 02:39 AM   #103
62stepside longbox
Thanks, Sounds like a good idea
Old 12-20-2015, 02:56 AM   #104
62stepside longbox
First day of Christmas break, so I got busy. Built a 1bbl to 2bbl adaptor plate out of aluminum. Ported and polished the inside so it should flow pretty good. Then I got started on the linkage, the pic below is the pedal assembly after I flipped the arm so when I give it gas it pulls instead of pushing. Then I built a rod with bends that goes from the pedal arm to the carb. Here's a video: http://youtu.be/PU0i3WgsB0Y
Old 12-20-2015, 09:33 AM   #105
Nice work on the linkage.
Old 12-20-2015, 04:21 PM   #106
TJ's Chevy
TJ's Chevy's Avatar
Looks good. That a carb off a gmc v6?
Old 12-20-2015, 08:20 PM   #107
62stepside longbox
Thanks guys. No the carb is a carter that I got for free from my dad's plymouth sine he went to a 4bbl.
Old 12-21-2015, 07:21 PM   #108
62stepside longbox
Made a cross member to put between the frame rails for the gas tank straps to bolt to. I will weld it in place later today.
Old 12-21-2015, 07:22 PM   #109
62stepside longbox
02
Old 12-21-2015, 08:52 PM   #110
62stepside longbox
Made some gas tank straps
Old 12-21-2015, 09:17 PM   #111
TJ's Chevy
TJ's Chevy's Avatar
Cool, has the carter seemed to make a difference?
Old 12-22-2015, 02:38 AM   #112
62stepside longbox
Not a huge difference but defiantly helps
Old 12-22-2015, 02:55 AM   #113
62stepside longbox
Ok no pics right now but I finished all of the gas tank straps and mounts and bolted the tank in. Now it's time to pull it back off and get the bumper mounted so I know where to cut the hole for the gas filler.
Old 12-23-2015, 02:04 AM   #114
62stepside longbox
Started working on mounting the bumper. Built one of two brackets that will be welded to the bumper and bolt to a piece of angle iron that will go inside the frame rails. I made the holes oblong so that the height of the bumper can be adjusted.
Old 12-23-2015, 06:44 PM   #115
62stepside longbox
Number 2 is finished. The old set of files is sure getting a good workout
Old 12-23-2015, 09:34 PM   #116
62stepside longbox
I found this inside my radio
Old 12-23-2015, 09:38 PM   #117
65sub
65sub's Avatar
Nice work on the bumper brackets. Did you really make the slots with a file?
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 12-23-2015, 10:01 PM   #118
TJ's Chevy
TJ's Chevy's Avatar
X2, Nice work.
Old 12-23-2015, 10:43 PM   #119
62stepside longbox
Thanks guys. Yes I made them with a drill press, a hacksaw but mostly files. Took a while. Times like these when a cnc plasma cutter would come in handy
Old 12-26-2015, 01:47 AM   #120
62stepside longbox
Installed my Christmas present! Sun pro super tach 2.
I'm impressed with the quality, compatibility and look.
Old 12-26-2015, 01:25 PM   #121
TJ's Chevy
TJ's Chevy's Avatar
Nice!
Old 12-26-2015, 09:30 PM   #122
rusty76
rusty76's Avatar
Cool
My build thread
Crossmembers CC
Old 12-27-2015, 11:32 PM   #123
sampsmit000
sampsmit000's Avatar
I am also 15. I am doing a 1964 k10. Go on youtube and check out "gibson63" He is doing a 1963 chevy. He does some of the best work i have seen. shows the steps in great detail. I would go and watch some of his videos. he is amazing.
sampsmit000 is offline   Reply With Quote
Old 12-27-2015, 11:57 PM   #124
TJ's Chevy
TJ's Chevy's Avatar
Hey I'm 16. Nice to see another guy my age here. lol 4X4's rock! I've seen many of Gibson's videos. He has a sweet truck. He's apart of this club. Username "Boat." He pops up once in a blue moon. Hope your truck is going well.
Old 12-28-2015, 02:42 AM   #125
62stepside longbox
Hey! Great to see more young guys on here. I would like to see what your doing to your truck. Do you have a build thread? What are your plans? I've seen some of gibson63's videos and he does great work.
