12-19-2015, 10:57 AM | #251 |
Second Chance Program
Re: 1977 Silverado Crew Cab.
For myself the motivation behind not using factory parts is just that I wouldn't have to try to find them and cut them off another frame. I can just click the order now button and be done. So it's a few extra bucks for the sake of convenience. I have thought of using all factory parts for a more factory look but several things keep me from wanting to do that. First off, the area where the shackle hanger is is different between the 2wd and 4wd so I'll have to trim that area. And I want to do crossover steering which doesn't fit well with a factory crossmemeber.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
12-21-2015, 08:02 AM | #252 | |
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF 2020 1500 Silverado 3.0 Babymax 2002 2500 Silverado- 6.6/ Allison 2010 CTS V- The "NastyBuzzard" 1979 Trans Am - Eventually getting 6.0/T56 swap with boost |
12-22-2015, 07:11 PM | #253 |
Coming back to catch up on your thread and noticed that the reflections in your buffed out paint job are much crisper than mine. You probably did a better paint job to start with, but could you tell us what grits you sanded (cut) with?
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
12-23-2015, 10:51 AM | #254 |
Looks better in pics than in real life! But, I ended up doing the whole 1000, 1500, 2000 routine. Ended up really not taking too long. Then I used maguires 105 on a wool harbor freight buff pad on my harbor freight buffer.
12-23-2015, 10:53 AM | #255 |
I'm at both an exciting point and bummer point with my build. It's exciting cause I can start driving it and using it as a truck again! But a bummer cause I have to put it on a hard hold until my kitchen remodel is done... Once I get back to it I'll be re doing the interior first off and then doing the 4x4 swap.
12-23-2015, 11:45 AM | #256 |
Well, looking forward to those jobs on the truck should motivate you to get through the kitchen rebuild and hopefully not let the little details drag out. Looking forward to seeing your next projects.
12-23-2015, 06:44 PM | #257 |
Thanks! Slapped the interior back in it and took it for a cruise!
12-24-2015, 02:35 PM | #258 |
Looks great! Nice to see you driving it after all that hard work.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
12-24-2015, 05:58 PM | #259 |
Even in the rain! Good for you.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
05-22-2016, 09:28 PM | #260 |
Put some late model wheels on the crew cab project today.
05-22-2016, 09:40 PM | #261 |
Looks good.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
05-22-2016, 09:44 PM | #262 |
oh yes
05-22-2016, 10:55 PM | #263 |
Truck looks great! Happy to see you back on it.
05-23-2016, 05:38 AM | #264 |
Thanks! I am absolutely dieing to get the trim back on!!
05-23-2016, 07:57 AM | #265 |
Wheels look very good on there. Trim is going to tie it all together - can't wait to see it!
05-23-2016, 09:09 AM | #266 |
wow that looks amazing!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
05-23-2016, 08:43 PM | #267 |
6>8 Plugless........
It's looking great with those wheels!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-23-2016, 10:59 PM | #268 |
Thanks fellas! Just trying to get through my insane honey do list so I can get back to it! I have done virtually nothing to it since freaking Christmas!
05-24-2016, 09:10 AM | #269 |
Honey do list gets me every time
05-30-2016, 06:56 PM | #270 |
Wheels look good! You going to run those with the 4x4 conversion with some taller tires? Those wheels are only 6.5 inches wide, but woul be perfect for some 9.00x16's.
06-02-2016, 12:29 AM | #271 |
looks great. wheels look good too.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
06-15-2016, 09:46 AM | #272 |
If things work out the way I think they will, I'll be ordering up the Fitech fuel injection next week. Seems like a pretty good setup!
http://fitechefi.com/default.asp.pg-GoEFI4 Also, just as an FYI, I have started a little (very little) side business and have started working on a website. If you want to check it out and tell me what you think that would be cool! It's at, http://gisiautoandfab.com/
06-15-2016, 09:55 AM | #273 |
I know the pieces fit
I really like that set up and look forward to seeing how it works for you.
06-15-2016, 09:58 AM | #274 |
i've really been itching for a "new" project to try one of the fitechs. i have yet to read a bad review on that setup.
06-18-2016, 12:52 PM | #275 |
Camaro Club
I am also interested in seeing how the FITECH system works for you. It was tempting me pretty bad earlier in the spring when Summit had it on sale.
