12-10-2015, 11:46 PM | #576 |
Re: 55 Wagon Progress
The braces for behind the lower skirt were mangled pretty well, had to untwist the pretzels to get accurate measurements..
Getting all the holes prepped... Welding in the new braces.. All the pieces of the puzzle... Well, almost.. Now to bust it apart for paint prep..
Robert |
12-11-2015, 12:20 AM | #577 |
Sure looks alot better...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-12-2015, 08:38 PM | #578 |
Well, only one more piece to make for the bus, we need a cap to join together two pieces of rub rail....
Bent up some 18 ga on the Baileigh magnetic brake... Then for the highly technical stuff, bent the rest using vise grips to clamp it in place and a dead blow to incrementally tap the ears around... Continued to use the hammer to tap it around, then tightened up the radius on this die/post dolly We'll get some paint on the bus parts tomorrow..
Robert |
12-12-2015, 09:17 PM | #579 |
Duplicate post
Robert Last edited by MP&C; 12-12-2015 at 09:37 PM. |
12-17-2015, 12:34 AM | #580 |
Got some paint on the bus parts tonight....
For the hardware, we media blast the heads and then paint....
Robert |
12-17-2015, 04:34 PM | #581 |
Looks good...Jim
12-18-2015, 11:40 AM | #582 |
Thanks Jim!
Robert |
12-19-2015, 07:21 PM | #583 |
The other night while spraying parts, I made a couple trips over to the bus location with the spray gun... in between coats, to get some primer on the bare steel we put in... SPI epoxy on the structural components..
.....and some epoxy AND yellow added to the nice scraped up lower corner.. Coming together... Rivets were media blasted and urethane only, just like the screws. This shows how well the paint holds up to the installation "abuse"... Done!
Robert |
12-19-2015, 07:56 PM | #584 |
Nice work Robert.
12-19-2015, 09:29 PM | #585 |
We knew you could do it!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-20-2015, 12:52 AM | #586 |
Turned out great...Jim
12-20-2015, 08:42 AM | #587 |
Nice work, I bet the original builder wasn't that concerned with priming behind the panels.
12-20-2015, 12:18 PM | #588 |
I have no time for this
It seems a shame they didn't have you fix the scrape ahead of the wheel while yo were at it.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
12-20-2015, 03:22 PM | #589 |
Yes, but this wasn't an insurance job, nor was the previous incident when that dent was added. With the cost being paid by the owner, sometimes a line is drawn in the sand as to what is worth the cost of repair.
Robert |
12-20-2015, 04:59 PM | #590 |
I hear ya I did collision repair for 15 years. Nice work on the bus always top notch
12-21-2015, 10:19 PM | #591 |
Thanks!
Dropped it off before work, picked it up afterward. After about an hour in the driveway with an air hose, the flow of trapped media is scarce, but I'm sure there's still some there. We'll get some SPI epoxy sprayed tomorrow night...
Robert |
12-22-2015, 01:59 PM | #592 |
That frame is a thing of beauty,
Quality of work is second to none. Even on a school bus no short cuts are taken. When Im out in the shop I reflect back to this build and it makes me try that much harder. Thanks for posting, even the small stuff. Merry Christmas and Happy New Year. |
12-22-2015, 02:35 PM | #593 |
OOOO Cleeeeean! Gotta love some blasted metal.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-22-2015, 06:41 PM | #594 |
Nice turn around time, frame looks great...Jim
12-22-2015, 11:40 PM | #595 |
Thanks for the comments fellas..
55 parts everywhere.... Two coats of SPI epoxy.... Had some left in the paint gun so a couple of extra pieces were moved in... Oh yeah....the "new" trailer wheels were all blasted and ready to go, so they got a couple coats on the back side...
Robert |
12-24-2015, 06:39 PM | #596 |
The frame had some slight pitting so the sides were hit with the DA to flatten things out a bit, and some Evercoat 416 used to address some of our plug weld grinding marks on the frame plates...
Here's the "winter" heating method for spraying in cold temps. 170,000 BTU aimed at the air return, and the air handler fan turned on constant to circulate the heat. Open window for air intake.. After three coats of primer, the sides of the frame are looking much better than before... Also got some more primer on these parts as well, should be ready for blocking in a few days.
Robert |
12-24-2015, 06:45 PM | #597 |
Have a Merry Christmas
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-24-2015, 07:02 PM | #598 |
Nice and Clean.
Merry Christmas |
12-25-2015, 01:04 AM | #599 |
Thanks guys. Merry Christmas everyone!
Robert |
12-27-2015, 07:54 PM | #600 |
The other day when we primed the frame a second time we also did the front side of the trailer wheels..
and today I mixed up some Centari that has been sitting on the shelf a few years.. It sprayed pretty decent... And more blocking.....
Robert |
