Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 12-20-2015, 01:52 PM   #1
DPowers
One foot in front of the other
DPowers's Avatar
Deluxe Heater FS
$50.00 plus shipping. All cables there. Good shape other than needs a lever. Can remove heater core and/or fan motor if wish. That may help with shipping, but still be around $25.00 I would assume. Looks like the ends on HC are dinged up. Reply in thread please.
DPowers is offline   Reply With Quote
Old 01-22-2016, 10:27 PM   #2
DPowers
DPowers's Avatar
Re: Deluxe Heater FS
ttt
Old 01-24-2016, 12:53 PM   #3
diver
what year truck thanks
diver is offline   Reply With Quote
Old 01-24-2016, 01:08 PM   #4
DPowers
DPowers's Avatar
Came out of a '65. But will fit 64-66.
Old 01-30-2016, 10:31 AM   #5
fleetman
Interested in your offer. My 66 is fairly rusted with beginning separation at the air box and fan housing metals. Can you tell if yours is not so rusted.
Another question when looking at yours.... Do you know what that hole in the fan motor houseing is for ?
Mine has no such hole.
Paul
fleetman is offline   Reply With Quote
Old 01-30-2016, 08:09 PM   #6
DPowers
DPowers's Avatar
I have no idea what the hole is for. I do know that the '65 parts truck I have has that hole and my '66 new fan motor also has it. If I don't sell it at the swap meet tomorrow- will post some better pics and go from there.
Old 01-31-2016, 09:22 PM   #7
DPowers
DPowers's Avatar
Let me know if this will work for you.
Old 03-03-2017, 08:52 PM   #8
Afirehawk1
Would you sell just the control unit and cables etc?
Afirehawk1 is offline   Reply With Quote
Old 03-03-2017, 10:53 PM   #9
DPowers
DPowers's Avatar
Let me see what I have.
Old 03-03-2017, 11:11 PM   #10
Afirehawk1
Ok thanks
I may need the blower too
Still trying to out how to put this truck back together
Do you know if the a/c vehicles use this setup in combo?
Old 03-03-2017, 11:17 PM   #11
DPowers
DPowers's Avatar
No it as different.
http://67-72chevytrucks.com/vboard/s...d.php?t=559436
Am at a swap meet this weekend, so will see what I have.
Old 03-03-2017, 11:29 PM   #12
Afirehawk1
Thanks for info and looking.
All very confusing though
So if i add factory a/c to the truck (i.e. Where the vents are added to the original ash tray location), how does the heat system tie in to all of this? Whats the difference between the standard 1 knob heater control and the deluxe? Sorry for all the questions,
I guess i dont know which direction to go ��
Old 03-04-2017, 10:10 PM   #13
DPowers
DPowers's Avatar
Sorry, not familiar enough with the A/C System to answer.
Single knob:
The heat control is done by pulling the knob out.
Fan speed is controlled by turning the knob.
To switch from defrost to heat is done by a lever on the box right above the trans hump.
Deluxe:
Has three levers- one controls fan speed, one controls heat level and the other switches between defrost and heat.
Here are the two deluxe controls I have right now. Levers will need to be replaced. Have two new cables that go with. $35.00 shipped if you are interested.
Old 11-12-2017, 02:21 PM   #14
number9
Junior Member
Do you by chance still have this deluxe heater assembly?
number9 is offline   Reply With Quote
Old 11-12-2017, 03:34 PM   #15
DPowers
DPowers's Avatar
Will check and see what I have.
Old 11-12-2017, 05:56 PM   #16
DPowers
DPowers's Avatar
This is what I have left. No controls. $65.00 shipped to you less heater core and fan motor.
Old 11-13-2017, 10:19 AM   #17
number9
Junior Member
Deal! but tell me what is different about this assembly and the standard heater set up?
Thanks, Gary
Old 11-13-2017, 12:25 PM   #18
MikeN
MikeN's Avatar
Thanks, Gary
I THINK....
Standard heater is either on or off - no modulation of temperature. Often it is too cold in the cab with heat off, but turning on the heat is then too hot.
Deluxe heater has a blend door with control cables, allowing you to adjust the temperature of the incoming heated air.
That's what I think, anyways.......
MikeN is offline   Reply With Quote
Old 11-13-2017, 12:57 PM   #19
number9
Junior Member
Thank you, that makes sense!
Mr. Powers if you pm me your pay-pal I will send you payment.
By the way the NOS window cranks were perfect!
Old 11-13-2017, 07:25 PM   #20
DPowers
DPowers's Avatar
Thanks, Gary
Thread here from the FAQ section.
http://67-72chevytrucks.com/vboard/s...d.php?t=488618
Old 11-13-2017, 07:25 PM   #21
DPowers
DPowers's Avatar
PM sent
Glad you liked the cranks.
