Old 12-21-2015, 01:26 AM   #101
AJCK87
Re: 1963 GMC C30 panel truck
I cut off the rivets, attaching the extension to the frame, swapped the extensions around. I added 1 1/4" square tubing. Just have it dry fit now. Will have to weld on some plates for the bumper brackets. Should work out
AJCK87 is offline   Reply With Quote
Old 12-21-2015, 01:27 AM   #102
AJCK87
found this mark on the extension
Old 12-21-2015, 01:29 AM   #103
AJCK87
Really excited, getting close to having the back end together.
Old 12-23-2015, 03:01 AM   #104
AJCK87
Fabricating some body mounts. Found some stainless tubing and sheet.
Old 12-23-2015, 03:05 AM   #105
AJCK87
Got the drivers side barn door mounted, just need to do some adjustment.
Old 12-23-2015, 03:10 AM   #106
AJCK87
I really like thee look of the 60 - 66 barn door set up!
Old 12-31-2015, 02:44 AM   #107
AJCK87
Had a chance to start shaping the walnut and fitting it to the dash.
Old 12-31-2015, 02:46 AM   #108
AJCK87
Really liking it! Trying to figure out the best way to mount the gauges and lexan.
Old 01-04-2016, 01:43 AM   #109
deejaaa1
that walnut is going to pop with a finish on it. looks good.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 01-04-2016, 04:05 AM   #110
The_Hub
The_Hub's Avatar
Very cool build. I'm liking that you're making more of the stuff yourself vs outsourcing. I love seeing people getting their own wheels turning. Subscribed for sure.
"There are seven days in a week. Someday isn't one of them."
http://67-72chevytrucks.com/vboard/s...d.php?t=686078
The_Hub is offline   Reply With Quote
Old 01-06-2016, 11:10 AM   #111
AJCK87
Thanks! I see such nice work on this forum, it s inspiring
Old 01-11-2016, 01:27 AM   #112
AJCK87
More on the gauge cluster....
Old 01-11-2016, 03:44 AM   #113
deejaaa1
turning out nice....
Old 01-11-2016, 08:49 PM   #114
65sub
65sub's Avatar
Cool looking gauge cluster
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-11-2016, 11:47 PM   #115
AJCK87
Thank you!
Thanks, looking forward to see your custom work with the gauges in your suburban.
Old 01-13-2016, 11:46 AM   #116
AJCK87
the gauge cluster turned out just the way I wanted! I was going to install the tach I have but I'm going to hold off, possibly get 2 gauges in there. I was thinking a tach and a fuel pressure gauge to monitor the output of my low pressure fuel pump.
Old 01-13-2016, 11:58 AM   #117
62stepside longbox
62stepside longbox's Avatar
Nice job on the gauges. What are they from?
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 01-13-2016, 12:34 PM   #118
AJCK87
Thanks! That are out of a 1992 Dodge 3/4 ton, went with them because I have them on hand and I will be using the Dodge wiring harness. The harness will just plug right in!
Old 01-13-2016, 01:12 PM   #119
TJ's Chevy
TJ's Chevy's Avatar
Liking that gauge cluster!
TJ's Chevy is online now   Reply With Quote
Old 02-05-2016, 12:47 AM   #120
62stepside longbox
Any updates on this?
Old 02-05-2016, 02:13 PM   #121
AJCK87
I have been working on wiring up the last tail tight with the LED board. Just on my way back from Vancouver with some parts I picked up at KMS tools. I got the inside front fender support patch panels for both the front fenders, hoping to get to those in the next few weeks. Also got some backing plates for the rocker fix. That is the plan for this next week, got time off and going down tomorrow. I hope to get the rear bumper mounted, both rockers repaired and some sheet metal repairs done. Also scored a used Crome front bumper, hopefully the right year this time hahahah. Updates to come
Old 02-07-2016, 01:17 PM   #122
AJCK87
Down island for the week, time to get some tasks knocked out! First things first, I just had to see how the gauge cluster looked in the dash.
Old 02-07-2016, 01:22 PM   #123
AJCK87
Next on the list for the dash. I figure I would install the "wait to start" indicator in the ash tray opening.
Old 02-07-2016, 01:25 PM   #124
AJCK87
Tackling the rockers this week.
Old 02-07-2016, 01:49 PM   #125
62stepside longbox
Nice work glad to see you making good progress
