Old 12-22-2015, 10:28 AM   #1
bigmac73
bigmac73's Avatar
new shocks ???
how do you know when it is time to replace the shocks,
I replaced the front shocks about 6 years ago with just a standard set of gas shocks, and installed a set of Gabriel air shocks on the rear,
wondering if it is time to replace the fronts again, when I bought the truck 6 years ago, the old ones I took off did not even move they where seized up
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 12-22-2015, 11:38 AM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: new shocks ???
Is the front really 'bouncy'? Meaning does it continue to oscillate after you go over a bump? If so, it's definitely time. If you care to take one off, set on end on the ground and push down on it - it should be pretty hard to push down and should come back up smoothly and fairly quick. If it pushes in really easy and/or stays in after you push it, it's done. Is there any oil around the piston or seal?
I'm sure others will chime in with more/better experience, this is just my redneck shadetree mechanic way of checking.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
