#26 |
Re: Gotta love the LS power
I have the ls bug and never going back . I sold ever piece of first gen stuff I had . There is no comparison in my opinion . I started with a stock 5.3 in my 82 and loved it . Now I have a ls2 ( 381rwhp ) with cam , intake , exhaust . Apparently that was not enough . I have a set of gm 243 heads cnc port from total engine air flow and new cam from Brian Tooley . Goal is 450rwhp . I think when I get to that point i will be done . Yeah right .
It amazing the power you can get from these engines . I also have a carbed stock bottom ls2/ls3 top end ( ported ) at about 600fwhp . Talk about fun to drive . Leestruk , I know where you are coming from . I think I have gone a little farther though and having a blast doing it . |
#27 | |
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#28 |
My impression is that 305 and 5.3 are the most common engines - certainly the most common V8s - in vehicles that offered them. Yes, the 5.3 makes a lot more power, but there were reasonable 305s as well.
1973 C20, 350/350 |
#29 |
DO NOT I REPEAT DO NOT UNDER ESTIMATE THE 4.8, mine runs like a beast in stock form.
#30 | |
#31 |
Yeh, 4.8L never put out much power and are not worth messing with.
http://youtu.be/MwJYPsJfDvE Not bad for a 4800 pound truck.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
#32 |
Glad I found this post. I was worried about the truck i just bought as a doner for my 1968 Suburban. Its a 2003 with a 4.8 240000km got the complete truck for $500 delivered to my shop. Really wanted a 5.3 but the price was right and the truck has no noise starting from cold at -8. I should be able to sell $500 worth of parts off it
![]() We do use the suburban to tow with. I figured that i will try it out and with a proper tune it should be better than the stock 327 thats in it currently.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#33 | |
#34 | |
1973 C20, 350/350 |
#35 |
Here's a great example of just how badly the "old-school" engines are starved for air.
Everyone knows Hot Rod does all their dyno testing at Westech, and they've recently done a couple of totally non-related articles/shows that are fairly eye popping. Example one: 383 Chevy, Vortec Heads, 230/236 hydraulic roller, dual plane intake, carb. 440.1HP@5600 / 464.9TQ@4200 https://www.youtube.com/watch?v=L-uV61qilqU Not a bad combo, and obviously due to the cubes excellent torque numbers. Example Two: Junkyard LM7 5.3. Stock dished pistons, stock 862 heads (small valve, known for being "junk" in the LS world), tiny 224/232 cam. 442HP@6200 / 412TQ@5000 http://www.hotrod.com/how-to/engine/...st-comparison/ Same dyno, incredible results. The 383 certainly made more torque, and would undoubtedly be faster in a vehicle going down the track. But for a run-of-the-mill, garden variety LM7 5.3 (I bought for for $550) with a cam change it is impressive and really illustrates how much potential lies in even the small cube LS engines.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
#36 |
The 4l60e does pretty good if you take care of it . Most high performance mods does beat on them pretty good . Heat is the biggest killer .
Get the biggest trans cooler you can fit in there and run it thru the radiator as well as the cooler . Don't skimp on the cooler . Also if you are getting a tune get the torque management turned off or reduced . It will keep the clutches from slipping as much when towing during shifts . |
