Old 12-22-2015, 09:03 PM   #1
warriorsimi
air compressors?
What is the difference between the ridetech air compressor and the viaair 450 ? Which is better? I bought the ridetech just wondering if Iade the right choice
72 gmc 1500 with leafs .
warriorsimi is offline   Reply With Quote
Old 12-23-2015, 12:03 AM   #2
Pro Performance
Pro Performance's Avatar
Re: air compressors?
What RideTech compressor in particular did you buy? All are good choices, so I am sure you made a good decision. What size tank are you running?
Pro Performance is offline   Reply With Quote
Old 12-23-2015, 12:39 AM   #3
warriorsimi
This one.
http://www.ridetech.com/store/thomas...ompressor.html
Old 12-23-2015, 12:41 AM   #4
warriorsimi
Not sure on tank but most likely a 3 gal.i am trying to get everything before I install it.waiting on air over leaf kit,c notch and flip are done.
Old 12-23-2015, 10:15 AM   #5
Pro Performance
The VIAIR 450C will be faster, as well as the 444C and 400C. That compressor is built by Thomas, and is a great compressor that will last you many years like the VIAIR. The Thomas is just a little slower than the VIAIR's. Not to say it is bad at all.
You made a great choice, and if you ever want more speed, you can add another Thomas or VIAIR compressor. Filling a 3 gallon tank will be Ok with the Thomas. If going with air on all 4 corners, then I would look at a 5 gallon, and a second compressors. But start with what you have already, and go from there.
Old 12-23-2015, 11:46 AM   #6
warriorsimi
Thanks for the help ,glad to know I am on the right course and that was my plan ,to add more if needed
.it is mostly for comfort not for play.thank you.
Old 12-24-2015, 01:32 PM   #7
SCOTI
SCOTI's Avatar
The Thomas comps will fill a 3gal tank from zero to 150psi in 6mins. The Viair's would prob be faster. I recall there was a difference between the Thomas & Viair in the 'duty cycle' when they ran.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-26-2015, 04:47 PM   #8
warriorsimi
I searched everywhere I could and found almost no info on it . I returned everything I ordered from ridetech and gonna go with viair dual setup.
Old 12-26-2015, 10:18 PM   #9
Pro Performance
We are a direct dealer for VIAIR, and be glad to help get you setup. We are back open Monday at 8am Arizona time.
- Travis
