Old 12-23-2015, 05:50 PM   #26
LeesTruk
Re: 250 to 5.3 swap
I cut the ends of the fuel sender lines so that compression fittings could be installed, then I used an assortment of Dorman Products fuel line repair parts, Dorman nylon fuel line (3/8, and 5/16) for my delivery and return lines. Using AN fittings and stainless sheathed fuel lines was too much for my fixed income (I'm retired). The most expensive part of the fuel system is the tool for inserting the fittings into the lines, but worth every penny for quick and correct assembly. It also helped having a hydraulic flaring tool with the correct dies to make the connection point on the outlet side of the filter/regulator
So far, the system has been trouble free
Lee
LeesTruk is offline   Reply With Quote
Old 12-23-2015, 06:22 PM   #27
LeesTruk
Re: 250 to 5.3 swap
Here's your part numbers
800-155 12" double beaded line 3/8"
800-154 12" double beaded line 5/16" (I only used one side of the line)
800-074 5/16" fuel line (10' roll)
800-075 3/8" fuel line (10' roll)
800-80 5/16" connector (2pc. box)
800-82.5 3/8" connector (5pc. box)
800-301 fuel line tool
All of this can be had, at Amazon or online somewhere, but most real auto parts stores will usually carry the parts. The tool they will probably have to order
Lee
Old 12-23-2015, 08:07 PM   #28
conman585
conman585's Avatar
Re: 250 to 5.3 swap
Lee
Thanks a lot Lee!!!
conman585 is offline   Reply With Quote
Old 12-23-2015, 09:06 PM   #29
65standard
65standard's Avatar
Re: 250 to 5.3 swap
On your AC compressor, where did you get those 90* fittings? I need something like those on my LSx swap too.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 12-23-2015, 11:12 PM   #30
foamypirate
foamypirate's Avatar
Re: 250 to 5.3 swap
ColdHose has them:
https://coldhose.com/specialty-fitti...-adapters.html
Search that page for "GM 5.3L Compressor Blocks"
foamypirate is offline   Reply With Quote
Old 12-23-2015, 11:16 PM   #31
LeesTruk
Re: 250 to 5.3 swap
Yep, that's where I got 'em
Old 12-30-2015, 01:43 PM   #32
Low Elco
Re: 250 to 5.3 swap
Great thread and nice work!
Low Elco is offline   Reply With Quote
Old 12-28-2016, 06:58 AM   #33
LeesTruk
Re: 250 to 5.3 swap
Well, it's been a year now, since the truck has been put together, so I thought I'd give sort of a "follow up". After some initial problems, which turned out to be a faulty PCM, and the "usual" new build bugs, the truck has been a real pleasure to drive!! Start-up is immediate in any temp., acceleration is tremendous (and scary if not paying attention), easy to drive, and a surprise in fuel efficiency/economy (19-20 mpg hiway). Overall, I couldn't be happier with the swap
Lee
Old 12-28-2016, 11:52 AM   #34
enroberts
Re: 250 to 5.3 swap
This was VERY helpful. i just ordered all the parts for the fuel system you used and posted here. Can you tell me what fuel pump and filter you used? My truck has a 4.8 with a return rail that I plan to use so I don't think I need a separate regulator as that system on the motor should take care of it, but I still need a pump and filter. The sending unit I bought is a Spectra Premium FG05M and I THINK the pump I need is a Spectra Premium SP1115 in tank pump. Thanks!
enroberts is offline   Reply With Quote
Old 12-28-2016, 06:01 PM   #35
LeesTruk
Re: 250 to 5.3 swap
Mr. Roberts, I gather your truck is pre-1973 so I don't know what tank you're gonna use. Concerning the fuel pump, I used an ACDelco e381 pump (in tank). You can also use a Delphi FE0114 pump (in tank) . For your filter, you can use an ACDelco GF652 (or equiv.). It has a threaded boss on each side, but you can get two of Dorman #800-170 (one for each side of the filter) and plug in the nylon fuel Lines (fuel in, fuel out) or you can use a Fram #g8219 (or equiv.) filter. It has a threaded boss on one side and a nipple on the other. In this case, you'd only need one of Dorman #800-170, then just plug in your fuel lines. For your return, just run your fuel line from the fuel rail back to the return side of your fuel bracket in your tank. BTW, the pumps and filters I've listed, are from a '97 Silverado. That should help with your conversations with whom ever you get your parts from
Lee
Old 12-29-2016, 06:55 PM   #36
AMERICAN PICK-UP
Re: 250 to 5.3 swap
NICE fuel system...
AMERICAN PICK-UP is offline   Reply With Quote
Old 12-30-2016, 08:46 PM   #37
LeesTruk
Re: 250 to 5.3 swap
Thank you, sir. Sometimes simple is good
Old 12-30-2016, 09:30 PM   #38
dec010974
dec010974's Avatar
Re: 250 to 5.3 swap
This is how I modified my sending unit.
dec010974 is offline   Reply With Quote
Old 12-30-2016, 09:31 PM   #39
dec010974
dec010974's Avatar
Re: 250 to 5.3 swap
Added to this. I have a 1980 GMC Sierra, C15.
Old 12-30-2016, 09:34 PM   #40
dec010974
dec010974's Avatar
Re: 250 to 5.3 swap
Good luck.
Old 12-30-2016, 09:43 PM   #41
dec010974
dec010974's Avatar
Re: 250 to 5.3 swap
This my forth LSx swap. You just can't beat them.
Old 01-03-2017, 10:51 AM   #42
enroberts
Re: 250 to 5.3 swap
how did you attach them?
Old 01-03-2017, 10:41 PM   #43
dec010974
dec010974's Avatar
Re: 250 to 5.3 swap
Enroberts, I had them crazed on.
Old 03-14-2017, 08:30 PM   #44
michael bustamante
michael bustamante's Avatar
Re: 250 to 5.3 swap
Thought I'd take a different approach for my fuel system. I'm using Dorman Products fuel line and fittings. We used this stuff in the repair shop and had good luck with it. The insertion tool is kinda pricey, and there are ways around using it, but the tool makes line construction so easy.
The nylon lines can be easily routed as long as there are no sharp bends, 'cause the stuff will kink. There are 90* fittings available if you need to make a quick turn. Also, use a heat shield of some kind (I use aluminized sheathing) if the lines pass near a heat source like exhaust pipes.
Another nice feature of the Dorman Products is that you can adapt their stuff to existing, or new, steel lines
Ready to put the front clip back on
Lee
Ok i need this fuel line with the fittings. Where can i find it?
1967custom
michael bustamante is offline   Reply With Quote
Old 03-15-2017, 06:15 AM   #45
LeesTruk
Re: 250 to 5.3 swap
You have to make it yourself. All of the stuff is from Dorman Products and should be easily obtainable from an automotive parts store or you can get the parts from an online source (Amazon, Ebay, etc.). I highly recommend getting the tool for inserting the fittings into the nylon line. It makes assembly a snap, once you figure out how to use it (no instructions come with it). I can post some pics of how to set it up, if needed. Also, make your turns gently, as the tubing will kink if the turn is too sharp! Overall, it's very cost effective and easy to use
BTW, just buy the parts as listed previously. Don't buy the whole fuel line kit from Dorman. It's way too expensive and it contains stuff you'll never ever need/use
Lee
Old 03-15-2017, 06:45 AM   #46
D13
D13's Avatar
Re: 250 to 5.3 swap
Lee
Yes please! This looks like a great solution for us 'chrome don't get ya home' guys. But the tool looks a little intimidating for an old guy like me.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 03-15-2017, 09:40 AM   #47
Rich84
Rich84's Avatar
Re: 250 to 5.3 swap
I'll be watching too..Getting ready to do the fuel system soon.
Thanks. Lee
Rich84 is offline   Reply With Quote
Old 03-15-2017, 10:10 PM   #48
LeesTruk
Re: 250 to 5.3 swap
Ok, here's a quick tutorial of how to use the Dorman tool (800-301) and how to make a fuel line with coupling. I'll be using the 3/8" nylon line and fitting
The first step is setting up the tool with the clamp (similar to a tubing flaring tool) and the fitting fixture
Insert your tubing into the clamp with about 1/4" protruding
Use some light oil of your choice, lubricate the barbs (makes insertion easier) then install your fitting onto the pointed fixture
Next, push the tool fixture and fitting into the tube opening then squeeze the tool handle until the fitting is fully inserted into the tubing
The finished product.
It's that easy
If you check the filter/regulator picture, you'll see the input side has two nipples made into it (3/8", 5/16"). The output side has a female receiver. I made a short double ended male tube, made from the Dorman 12" steel line. This line only has one barbed end, so I used my hydraulic flaring tool and fuel fitting die to make the second male end to insert into the regulator, then just plugged the new fuel line onto it.
Don't try heating the nylon tube and think you can just push a fitting into it. The nylon will not get soft and pliable. Also, it doesn't have a memory, meaning it won't just go back to what size it was, forming a tight seal. Once it's out of shape, that's the way it remains!
Lee
Old 03-16-2017, 06:16 AM   #49
D13
D13's Avatar
Re: 250 to 5.3 swap
AH, I see. You needed a male end to mate to the FFR, which you made from steel line. The other end fits the nylon fitting. Question - is the required end for the steel line to the nylon fittings a simple bubble type flare, a barb flare (like the vapor line shown in your sender unit picture), or just straight line?
BTW thank you very much for the info.
1987 2 ton
Old 03-16-2017, 07:00 AM   #50
LeesTruk
Re: 250 to 5.3 swap
If you look at a picture of Dorman double beaded line (800-155) you'll see how the lines are connected. It's neither a bubble nor barb, but a raised surface that is formed when the line is compressed on itself. The fore mentioned line is 12" in length, but I thought it would be too much leverage on the FFR. That's why I shortened it to about 2". I suppose if you anchored the output line and FFR really well, then there shouldn't be a problem
