Old 12-27-2015, 01:59 PM   #1
suburban99
suburban99's Avatar
62 C10 Instrument cluster junkyard swap?
62 C10 LS 5.3 4L60E swap:
Has anyone tried to use a "junkyard" cluster out of a newer car/truck to allow the use of electronic gauges including the speedo? I just can't justify paying the price of electronic gauges/speedo on my build. You can get the full cluster from a late model vehicle with speedo/tach/oil/water/fuel..for $40-$70...something that will fit inside the stock '62 cluster hole...anyone done it?
suburban99 is offline   Reply With Quote
Old 12-27-2015, 02:25 PM   #2
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: 62 C10 Instrument cluster junkyard swap?
Look at Post #2 in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=502712
Classic v6 GMC's is offline   Reply With Quote
Old 12-27-2015, 04:42 PM   #3
suburban99
suburban99's Avatar
Nice but too fancy and $$$ for my current build.
Old 12-27-2015, 05:12 PM   #4
Classic v6 GMC's
I think that is the stock type gauge cluster out of the 2003 truck. They just added the white backgrounds behind the gauges. https://www.google.com/search?q=2003..._AUIBigA&dpr=1
Old 12-27-2015, 09:49 PM   #5
PGSigns
PGSigns's Avatar
The clusters are coded to the vin and that may take some work to figure out. If you are up to the wiring it takes You could give it a try. The cluster from the donor that your engine and computer came from may be the easiest to get to run.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-27-2015, 10:09 PM   #6
suburban99
suburban99's Avatar
Jimmy
Truck is currently running, just looking to see if anyone has used a non GM cluster...Kia Sedona maybe? small sized cluster that would fit in the stock opening preferably with a tach, electronic speedo and oil and temp...cheap at the auto wrecker.
