Old 12-27-2015, 07:57 PM   #101
akabikerbob
A little closer look
akabikerbob is offline   Reply With Quote
Old 12-27-2015, 07:59 PM   #102
akabikerbob
I have to say I'm getting better at the sheet metal work. I can build a lowboy trailer from scratch but sheet metal work is an art!! Getting better though
Old 12-27-2015, 08:35 PM   #103
Arnulfo
Re: 1970 c10 lq9 build
Beautiful work! What did you use to cut your frame? Looks very precise.
Arnulfo is offline   Reply With Quote
Old 12-27-2015, 08:40 PM   #104
akabikerbob
I used a plasma cutter with a straight edge as a guide and a piece of pipe as a guide for the radius. Thanks!!
Old 12-30-2015, 12:55 AM   #105
akabikerbob
Got my epoxy primer and poly primer in today. Now it's time for some light dent removal. Some mud and then prime.
Old 01-03-2016, 12:28 AM   #106
akabikerbob
Did my c-notch today. Still going to box the inside and remove shock crossmember to make room for a new coilover crossmember
Old 01-03-2016, 12:28 AM   #107
akabikerbob
Cut out
Old 01-03-2016, 12:29 AM   #108
akabikerbob
Tacked in
Old 01-03-2016, 12:30 AM   #109
akabikerbob
Welded up
Old 01-03-2016, 12:30 AM   #110
akabikerbob
All finished
Old 01-06-2016, 10:34 PM   #111
akabikerbob
Replaced my rear crossmember today.
Old 01-07-2016, 03:19 AM   #112
DBK81
DBK81's Avatar
What is the sizing on those tires? 340's?
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 01-07-2016, 04:47 PM   #113
akabikerbob
they are 29x18r20 mickey Thompson radials
Old 01-07-2016, 05:03 PM   #114
snipescastle2
snipescastle2's Avatar
Talking Re: 1970 c10 lq9 build
Steam rollers!
Ben
snipescastle2 is offline   Reply With Quote
Old 01-09-2016, 06:35 AM   #115
Clndesl
What are your plans for the rear axle? I am doing a similar build but can't decide on rear wheel size because I am not sure what is involved in narrowing the rear axle.
Clndesl is offline   Reply With Quote
Old 01-09-2016, 06:28 PM   #116
akabikerbob
I am going to be narrowing the stock 12 bolt. With ford big bearing axle ends to get rid of the c clips and then 4:10 gears and a posi. I will narrow it as close as I can get the backing plate to the trailing arms and then order my wheels based of of that
Old 01-09-2016, 06:51 PM   #117
Clndesl
Thanks for the reply and that was I was thinking about doing too. I too am keeping the trailing arms so I figured that would be my limiting factor. I am pretty close by you, what do you think it would cat me to have one of the shops you work at chop my axle down? It's a 72 axle
Old 01-09-2016, 07:35 PM   #118
akabikerbob
You would need axle ends that would run you a little over 100 and then about 225 for labor for putting it in a jig and cutting down and welding new ends on
Old 01-12-2016, 09:50 PM   #119
justinl6050
nice build. would love to do a complete build someday
justinl6050 is offline   Reply With Quote
Old 01-15-2016, 08:58 PM   #120
akabikerbob
Got my trailing arm crossmember in today.
Old 01-15-2016, 09:00 PM   #121
akabikerbob
One of the last Cali combos that grant Kustoms produced. Going on this weekend
Old 03-03-2016, 12:24 PM   #122
knomadd
knomadd's Avatar
I'm really liking the metal work on this build. Keep it up!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 06-07-2016, 11:29 AM   #123
mcnichog
Everything looks great!
Any updates???
mcnichog is offline   Reply With Quote
