#226 |
Re: 1961 Crew Max
A bit overkill....hahahha
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#227 |
Re: 1961 Crew Max
Hey,
Did some research on the hydraboost. Maybe you know this, but the hydraboost can be rotated so that the avcumulator will face the driver side instead of against engine. That will probably make it fit! I'll have this tested soon👍 Your frame looks killer! /Thomas
1965 c10 BBW LWB - Duramax 2010 Camaro SS - Whipple (721hp) 2017 Volvo V60 diesel-hybrid (233hp) 2008 volvo XC70 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=677577 |
#228 |
Re: 1961 Crew Max
Nice job on the frame stiffener.
I feel motivated every time I get an update on this build. |
#229 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Re: 1961 Crew Max
Little more progress yesterday. Got all the rockers closed up and most of the rust repairs done along the bottom outside area. most likely when the cab goes back on we will cut out most of the inner floor to build a tunnel. We also made a center cab support that will have a new body mount to the frame. It seems like they should have put these in from the beginning. There is 72" from front to back cab mounts. We also kept warm by catching the seat on fire in the cab. Thanks CHIZZLER
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#230 |
![]() Join Date: Jul 2012
Re: 1961 Crew Max
Looks good Chizzler. Glad the seat fire didn't get out of hand.
#231 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 1961 Crew Max
Great work! Do you have to have a high tunnel and use buckets or will you be able to use bench type seats still?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#232 |
Re: 1961 Crew Max
Right now the output shaft from the trans is at floor level. There will be a tunnel through most of the cab. Going to use early blazer bucket seats with some kind of console in the middle probably built into the tunnel. Going to try and use the rear seat from the d-max donor as it was a extended cab and folds up. Thanks
#233 |
Re: 1961 Crew Max
Quick update. Cab is back on to start building tunnel and floor. Started by trimming firewall and making clearance. Had to add A piece at the top edge for the turbo shroud. Next we took a piece and rolled it to fit the new cut out in the firewall. Cut grind cut grind cut grind. Finally fits. Once that was tacked took and made a template out of cardboard for the second piece then transfered to metal. Overall fit is good. Tacked it in. We are trying to leave as much room as we can for pedals. Thanks CHIZZLER
#234 |
Re: 1961 Crew Max
Having to cut into the firewall and reconfigure the tunnel takes time. Especially to make sure there is plenty of room for the pedals.
Looks clean, nice work. Are you running heavier springs up front for the added weight of the motor and trans? |
#235 |
Re: 1961 Crew Max
That looks great! That was the biggest hurdle in my Vette. Trying to keep enough room for your feet and pedals.
#236 |
Re: 1961 Crew Max
awesome build!!
#237 |
Re: 1961 Crew Max
Made it out to the shop yesterday. More tunnel and floor work. Making the tunnel round not square will allow it to be much tighter. I need all the room i can get for pedals. Overall fit is good with the new low back buckets. Plenty of room between for a console. We cut the section of floor out that was added to stretch it and will be building a better floor structure. You can see the turbo down pipe is right at the bottom corner. Going to get a aftermarket pipe and try to cut and turn it to pass over the frame right at the toe board. Its gonna be tight. Thanks CHIZZLER
#238 |
Re: 1961 Crew Max
Looks good .
#239 |
Re: 1961 Crew Max
Nice work on the transmission tunnel. Are you using a slip roll?
#240 |
Re: 1961 Crew Max
Good looking tunnel Chizzler. What gauge sheetmetal are you using.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#241 |
Re: 1961 Crew Max
You aren't kidding. Don't think you could even get the tip of your pinky in there.
Looking good |
#242 | ||
Re: 1961 Crew Max
There is about 1" all the way around.
#243 |
Re: 1961 Crew Max
#244 |
Who Me?
Re: 1961 Crew Max
Great build.. Always enjoy the updates!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#245 |
Re: 1961 Crew Max
Great work!
#246 |
Re: 1961 Crew Max
Chizzler you are doing great work. Tunnel and firewall look great. Just to let you know, I had Ken Wolkens do my harness work. I also had a reference of his do my ECM and TCM work. Cranked my engine this weekend and it fired off first try with a couple of wires.
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540 1992 Chevy K1500 Silverado ECSB 1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered |
#247 | |
Re: 1961 Crew Max
#248 | |
Re: 1961 Crew Max
The Snortin' Bull |
#249 |
Re: 1961 Crew Max
Todays progress. We got the middle cab supports in place with energy suspension poly mounts and made a weld on mount. We started building a new floor support. The original pieces they welded in when they stretched it were not great. We came off the front to back floor supports and made a inner structure that now is closer to the middle and has a drop down under the driveline. We also added supports for the front bucket seats. The sheet metal was left long in the middle till we build the tunnel. CHIZZLER
#250 |
Re: 1961 Crew Max
Well Chizzler, I just spent as long as it takes to go through all three your build threads.
And all I can say is Man, you are very good. I love your vision and execution.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
