Old 12-13-2015, 06:23 PM   #151
namloc
namloc's Avatar
Re: The Snortin' bull
Rear brakes's all assembled and reconditioned and ready to from backing plate's out.Waiting for axle's now to come from being redrilled.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 12-20-2015, 02:35 AM   #152
namloc
namloc's Avatar
Adapting the 1960 gmc hubcap's to later model 5 on 5 wheel's.This is still a budget build . I had some (impala) Caprice Police Cruiser rim's around so I used these for the Bull at this time. Kept it simple to keep the cap's retained.
The Snortin' Bull
Old 12-23-2015, 12:18 AM   #153
namloc
namloc's Avatar
The axle's are back.Reinstalled them today into housing. Redrilled for 5 on 5 and turned down in the center to fit the later model drum's.FYI or BTW on these early Dana 44 axle's they use same as the big Ford ( torino ) axle bearing's very common and they are 30 spline axle shaft's.
The Snortin' Bull
Old 12-26-2015, 06:42 PM   #154
namloc
namloc's Avatar
Rear brake drum's are on. As other's have noted in the past on these build's 11 x 2 finned from later c-10's work and clear the backing plate.
The Snortin' Bull
Old 12-26-2015, 06:44 PM   #155
namloc
namloc's Avatar
Also the correct rear park cable's arrived and are now installed.Napa still offer's these.LMC list them though they are not for the 1960 to 63 dana's.
The Snortin' Bull
Old 12-27-2015, 02:11 PM   #156
namloc
namloc's Avatar
Rear wheel's back on .
The Snortin' Bull
Old 12-28-2015, 12:08 AM   #157
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Lookin very nice. Love the caps.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 12-28-2015, 12:48 AM   #158
Ronzo
Ronzo's Avatar
Those caps really set it off, nice touch.
Ronzo is offline   Reply With Quote
Old 12-28-2015, 11:36 AM   #159
namloc
namloc's Avatar
Thank you .,The cap's i just wanted to try to make work.
The Snortin' Bull
Old 12-28-2015, 11:38 AM   #160
namloc
namloc's Avatar
Thank's .I think the cap's are cool for a 1960 GMC there kinda' fancy.
The Snortin' Bull
Old 01-03-2016, 09:35 PM   #161
namloc
namloc's Avatar
Exhuast need's to be run off the shorty block hugger header's before I start the engine. Gettin there . Check list to move the truck on it's own down to few item's.
The Snortin' Bull
Old 01-06-2016, 11:12 PM   #162
namloc
namloc's Avatar
a little frame webbing insulation for the bed wood to lay on bed cross rail's.
The Snortin' Bull
Old 01-08-2016, 12:27 AM   #163
CHIZZLER
CHIZZLER's Avatar
Getting closer and closer every update.
61-crew cab D-max
Old 01-08-2016, 04:46 PM   #164
Ronzo
Ronzo's Avatar
It's funny, I'd never see a hubcap like yours till I saw this thread. Then 4 of these showed up for sale locally, still in the factory boxes, never installed. 1955 though, you said yours were 1960?
Old 01-09-2016, 12:59 AM   #165
namloc
namloc's Avatar
Yes the caps are 1960. The one's you are showing are sweet gem's.
The Snortin' Bull
Old 01-09-2016, 11:48 AM   #166
Ronzo
Ronzo's Avatar
naloc, check your private message folder.
Old 01-10-2016, 08:24 PM   #167
namloc
namloc's Avatar
I did manage to get a bit of time in this weekend on the Bull .Not much Thuough, got the exhaust started .The first foot of the down tube's.
The Snortin' Bull
Old 01-16-2016, 12:24 AM   #168
namloc
namloc's Avatar
Piece by piece.Fab up exhaust front to back. This is alway's time consuming.There are very talented exhaust builder's out there though on my home garage floor I am not one of them.Especially on a bagged truck.
The Snortin' Bull
Old 01-17-2016, 03:06 AM   #169
namloc
namloc's Avatar
Right side exhaust together to midpoint of truck.
The Snortin' Bull
Old 01-17-2016, 03:09 AM   #170
namloc
namloc's Avatar
one last underhood install the detent cable bracket for the transmission tv cable.
The Snortin' Bull
Old 01-17-2016, 03:12 AM   #171
Grizz1963
Grizz1963's Avatar
Amazing looking work here.
Every hour you get is progress.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 01-17-2016, 10:14 PM   #172
namloc
namloc's Avatar
Got the lh and rh front exhaust pipe's done and hung.The goal is tuck up high and muffler's to the rear past the cab floor .
The Snortin' Bull
Old 01-17-2016, 10:16 PM   #173
namloc
namloc's Avatar
This is hour's into pipe's finally a muffler .More pipe to fab.to come.
The Snortin' Bull
Old 01-17-2016, 10:20 PM   #174
namloc
namloc's Avatar
The easy way out build a couple of stack's up thru bed floor.Just playin' around.Fab'd pipe's to flow out to side's to follow kickup and to rear of bed into corner's to dump.
The Snortin' Bull
Old 01-17-2016, 10:21 PM   #175
namloc
namloc's Avatar
Thank's Grizz.5 Minute's or 5 hour's a day the past 18 month's to get this point.
The Snortin' Bull
