12-29-2015, 06:02 PM | #1 |
Cab fuel filler to rear tank
Has anyone done an original looking cab mounted filler to a rear fuel.
12-29-2015, 06:43 PM | #2 |
Re: Cab fuel filler to rear tank
I think most have tried to stay away from Blazer type fuel fill. Not wanting to cut into a bedside but going for a hidden fuel filler. I used an 1 1/2" boat fuel fill in my blazer, trying to keep a smooth bedside but also use the original hole. If you have an 1 1/2 inlet into your tank it's not a bad option......http://67-72chevytrucks.com/vboard/s...d.php?t=439895
12-29-2015, 07:15 PM | #3 |
I'm talking about the existing filler hole in the cab. Running new filler tube to reach rear tank
12-29-2015, 07:28 PM | #4 |
Drewskiren did something along those lines on his crew cab build. Here's a link to one page of it.
http://67-72chevytrucks.com/vboard/s...t=tank&page=80
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
12-29-2015, 07:33 PM | #5 |
I doubt you could get it to accept the fuel and why bother movin the tank to the back if your going to have the fuel up your a$$
12-30-2015, 08:46 AM | #6 |
Robert Duvall "Days of Thunder" I'm gonna give you a fuel line that'll hold an extra gallon of gas.
12-30-2015, 09:33 AM | #7 |
Sounds like a bad idea all around. Seems like a great way to accumulate condensation to feed the ethanol, a mile of filler that could leak, need to account for body to frame as well as cab to bed and bed to frame movement. And if you go through the floor, how much fall can there be to way back at the fuel tank. If you've ever had a square body or newer truck you know how onry they can be to fill sometimes, due to the path not being so direct. Maybe it's just diesel in the cold, but nothing sucks like standing in the cld blowing wind with a pocket full of gas money, a job to get to, and the truck will only let you dribble the fuel in while hand freezes because it won't let you set the trip lever
12-30-2015, 01:42 PM | #8 |
My bed will be raised 2 inches so lots of slope. I just like the original look on the outside of this truck and won't be painting it. This truck will never see winter. I have no side markers, don't like bed fillers, too low for license plate ( I'm to old to bend over). So I'm undecided.
01-03-2016, 09:21 PM | #9 |
Rear taillight fill?
01-04-2016, 05:07 AM | #10 |
About 4 years ago or so there was a build that the guy was trying to make that happen, he had drilled a hole in the cab and had mocked up a long length of PVC pipe about 2" diameter from the cab back to the tank. I have not found or read any completion to the guys mock up, cant recall his handle or the build name, he did say the PVC was going to be replaces with different tubing, i would assume something like exhaust pipe..
I did find this in a search, not much help.. http://67-72chevytrucks.com/vboard/s...fill+tube+pipe . . . . .
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-08-2016, 08:27 PM | #11 |
This is what I came up with and built.
05-08-2016, 08:56 PM | #12 |
Well, there you have it. It can be done.
I'd like to one day move my tank to the rear and use the side marker light (stepside) to hide a the filler cap. I am crazy about "just in case" tools so I'd really like to free up that space behind the seat. |
05-08-2016, 09:18 PM | #13 |
If I had side markers, that's what I would have done. But then again I like to be different and challenge myself. Plus it looks original.
05-08-2016, 09:27 PM | #14 |
Its not a matter of "if" it can be done. After all countless IHC pickups like my 75 used a filler tube through the cab leading down to the passenger side tank that ran under the cab and bed. The driver's side (aux tank) has a filler in the front fender.
I am in agreement with SpecialK that this may introduce more problems than it solves. At a minimum I feel it needs a float valve at the tank inlet and beads in the tubes to allow a more positive clamping of the hose joints.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 05-08-2016 at 09:33 PM. |
12-14-2016, 12:25 AM | #15 |
Just an up date on this, I've put over 1000 miles on it with several top ups. I hold the gas nozzle at 3/4 to full and the gas flows in well. I've had people ask if it had the original tank because of the fill local. It has worked out great.
12-14-2016, 01:09 PM | #16 |
Great that you did this, as that's exactly what you wanted. My own approach would have been to go to the Blazer tank, modified to use a Camaro style filler located behind a hinged rear plate. To keep the original look, I'd have left the original filler on the cab, and welded the tube closed, to prevent any idiot from pumping the cab full of hi-test!
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
12-14-2016, 03:48 PM | #17 | |
12-15-2016, 02:32 AM | #18 |
Yeah, I know what that feels like
12-15-2016, 08:42 AM | #19 |
what was the point of moving the tank?
seems like a bunch of extra work when you could have just left the tank where it was behind the seat |
12-15-2016, 09:53 AM | #20 |
/\ what Joe said!
12-15-2016, 11:22 AM | #21 |
17 gallon to 22 galloon, weight on the rear axle for control, no more gas tank in the cab, more storage behind the seat for stuff and speakers, no filler in the box to spill gas in the box, easy fill local. Yes it was a lot of work but I'm like custom touches. I have the best fabricator working on my stuff and I trust him with my life. Why be normal or grow up if you don't have to. I have one off fabbed parts and touches all over the truck, this is just one of my great ideas I think. No one else has this but me.
12-16-2016, 11:33 AM | #22 |
I'm sorry man. I'm all for custom, but I think this is just dumb.
moving the tank for more capacity- ok great idea. running filler in stock location- you still have gas in the cab. not the tank, but you still have the potential for gas to leak inside the cab so any safety you gain by moving the tank is gone. weight for control? its 30 lbs and you have the stock engine from what I saw so you aren't drag racing so this 30 lbs is totally irrelivant. |
12-16-2016, 03:10 PM | #23 | |
A gallon of gasoline is roughly 6lbs so Metaldoc did add 30lbs. But he moved over 120lbs towards the rear of the truck, not just 30lbs. Doesn't matter what you're doing, moving weight to the rear on a nose heavy truck is a win in my opinion. As far as safety. Yeah there's still at least the potential for fuel in the cab with this setup. All the parts inside the cab are solid with no rubber joints so leaks inside the cab while filling aren't really an issue unless there's a bad weld. Biggest issue is with being rear ended. If he was hit hard enough to crush the tank and push fuel up the filler it's likely the tank would be punctured as well reducing how much fuel is forced forward. Then there's the 2 couplings outside the cab which could come apart before fuel was forced into the cab. It's not 100% but either of those could happen reducing or eliminating fuel even coming back into the cab at all. Plus the parts inside the cab are solid welded so they'd have to break open before fuel any fuel that was forced forward could leak into the cab. If you're not comfy with those odds nobody will blame you for going with something different. We all make choices with our trucks based on tastes, skill level, etc. In my opinion there's no reason to call this unsafe, not worth the effort and it especially can't be called dumb. Last edited by Overdriven; 12-16-2016 at 03:18 PM. |
12-16-2016, 04:45 PM | #24 | |
12-16-2016, 07:47 PM | #25 |
What is the problem with this ? I say it is no different than some of the other custom mods people have tried. I say great job! ! 😆 As far as the dumb comment i believe it says on the rules of this forum if you don't like it keep your comments to yourself. What an ignorant thing to say.
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
