Old 12-29-2015, 10:42 PM   #1
Longley428
Lower A-arm Help
Hello, I have a 69 scsb C/10 and I have recently purchased the Hotchkis 4/6 lowering spring kit. I started on it tonight and I can’t seem to get the lower control arm/a-arm to break free and drop from the spindle. Shock is off, tie rod is off and loosened the the nut holding the lower arm in but did not take all the way to ensure the spring doesn’t fly out. I have used a big hammer and bars, tuning fork etc. and nothing will break it free. I soaked everything down last night and again today with PB Blaster. Any suggestions??
Longley428 is offline   Reply With Quote
Old 12-29-2015, 11:43 PM   #2
tinydb84
tinydb84's Avatar
Re: Lower A-arm Help
Hit the spindle on the side where the ball joint goes through. Hard.
David
Instagram: myfabguy
Old 12-29-2015, 11:48 PM   #3
Longley428
I'm using a 4lb sledge hammer, is that big enough?
Old 12-30-2015, 01:28 AM   #4
SierraMtns
SierraMtns's Avatar
Do you still have a the spring under pressure? And yes hit it hard.
SierraMtns is offline   Reply With Quote
Old 12-30-2015, 01:43 AM   #5
SierraMtns
SierraMtns's Avatar
Start at 2:30
http://powernationtv.com/episode/TT2014-06/in-the-weeds
Old 12-30-2015, 03:18 AM   #6
BigMike
BigMike's Avatar
^^^ Just as SierraMtns suggested. If it does not come loose it means you're not hitting it hard enough. Make sure to put the jack under the lower A-arm till it is just resting on it (under where the ball joint is), this will keep the spring from flying out because the jack will stop it.
BigMike is offline   Reply With Quote
Old 12-30-2015, 09:46 PM   #7
Longley428
Well went and bought a new longer handle hammer and still no luck, I've hit and pryed and still no luck. I attached a picture of what I've got, if someone could circle the exact spot I need to focus on hitting please help!!
Old 12-30-2015, 10:16 PM   #8
1978chev
looks like your hitting it in the right spot i have had some real hard ones the only advice is get a BIGGER hammer you can try to have some one get a pry bar and pry down while you hit it just be carefull
1978chev is offline   Reply With Quote
Old 12-30-2015, 10:26 PM   #9
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Anywhere on the center line of where the black line is.
Might help to remove the steering arm.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 12-30-2015, 10:41 PM   #10
Longley428
Thanks! I will try that and see what luck I have. Has anyone out there done this Hotchkis 4/6 spring kit? Would love to see some before and after pics of them.
Old 12-30-2015, 10:52 PM   #11
Steven R
all I can add to this is that when I had to do mine this way I thought you all were full of crap, just hit it with a bigger hammer ya right... Until I finally got mad and got out the 8 pound. I hit it with all I could at the odd angle.
It popped with the first blow. I am now abeliver in this method but man o man I have had some hard ones and other that a small 2 lb did the trick.
hope it works for you
Steven R is offline   Reply With Quote
Old 12-31-2015, 12:53 AM   #12
Houston Ben
Houston Ben's Avatar
I dented my a-arm before it broke loose!
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
