![]() Join Date: Oct 2015
Door problems
Hey guys, is there a trick to getting door adjusted? I put a new upper hinge on and am having a hard time getting it adjusted to close right.
![]() Join Date: Oct 2010
Re: Door problems
I don't know at what point your truck is. If you did this without removing the fender it is harder to do. I had the fenders off while doing alignment of the doors. I start with some wooden paint sticks. Place the amount needed on the rocker panel under the door. Then place the door into the opening. Add or take out till the door fits the opening. adjust up and down and back to front to get the gaps acceptable. Then snug the bolts on the hinge. This will change the door location sometimes requiring some more adjustments. Remember the bolts on the front A post adjust front to back and up and down. The bolts on the door itself adjust the door in and out. This takes a some time but can be done. If you still have the fender on you can still do this but the bolts can be harder to access. Hope this makes sense to you and you are able to complete your alignment.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Re: Door problems
Imagine having that job at the factory back then, what a pain in the @#$
![]() Join Date: Jul 2014
Re: Door problems
Not that I have been incredibly successful at this, but I used my engine hoist and some ratcheting straps to help support the door, this made things a lot easier on my back. I got the door close and ended up adjust the latch on the cab.
![]() Join Date: Mar 2012
Re: Door problems
those guys probably did it some many times that it was a piece of cake.
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
