Old 01-01-2016, 05:12 AM   #1
WOLFMANmike
WOLFMANmike's Avatar
steel braided fuel line and vacuum line
I have a question do any of you know of a brand of steel braided lines that do not require you to run AN type fittings ? I'm looking for stuff I can still use hose clamps with
WOLFMANmike is offline   Reply With Quote
Old 01-01-2016, 01:26 PM   #2
siggyfreud
siggyfreud's Avatar
Re: steel braided fuel line and vacuum line
The braided lines I use don't require AN fittings that I know of. They're just loose ends that I install AN fittings onto. I don't see any reason you couldn't just use a hose clamp on them.
siggyfreud is offline   Reply With Quote
Old 01-01-2016, 02:19 PM   #3
ls60apache
I have used hose clamps on braided line before it didn't look so good ,when its cut it frays out and not to mention painfull to the fingers.i never did it but contemplated using some clear epoxy around the area before I cut it,and maybe that would hold the strands together.idk they also make a nylon type braided line if that will work for you. good luck.
ls60apache is offline   Reply With Quote
Old 01-01-2016, 02:54 PM   #4
WOLFMANmike
what is the brand of nylon hose your talking about ? Where can I find it ?
Old 01-01-2016, 03:35 PM   #5
siggyfreud
siggyfreud's Avatar
You can tape over the ends of the hose before cutting to help reduce frays, though I couldn't even eliminate them totally.
Old 01-01-2016, 05:53 PM   #6
ls60apache
Summit racing the brand I was looking at is Fragola series 3000 black nylon hose also has hose clamp ends the look look like an fittings. also Earls,Aeroquip,Russel and even summit has there own line of nylon braid hose.check out there online catalog.
Old 01-01-2016, 05:55 PM   #7
ls60apache
oops sorry double post
Summit racing the brand I was looking at is Fragola series 3000 black nylon hose also has hose clamp ends the look look like an fittings. also Earls,Aeroquip,Russel and even summit has there own line of nylon braid hose.check out there online catalog. www.summitracing.com.
Old 01-01-2016, 07:49 PM   #8
WOLFMANmike
ok ty for that
Old 01-02-2016, 02:09 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
FWIW guys, I personally avoid doing this unless you trim away the braided area where you'll be clamping (or expand it and use a clamp cover). The reason I say this is that the steel mesh can bunch up, catch in the clamp, or otherwise contribute to a less-than-ideal clamping situation. The inner rubber hose can be clamped like any other. Taping helps with this, but it still is another layer between your clamp and what is to be clamped.
Vacuum lines, anything low pressure is probably fine. Just use common sense if your ever doing it on anything that requires a high clamping force, or high pressure resistance.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
