Old 01-02-2016, 05:31 PM   #1
XwalkerX
factory tach with 5.3
so i have a tach dash in my 72 c10 that im trying to get to work with the l33 swap. i purchased the dakota digital SGI-8E tach converter since i understand that the tach output from the harness is equivalent to a 4cyl setup.
pic for reference
i ran power and ground to the box.
i ran ground to the tach, the tach power wire i have going to the "normal" port set to 8cyl and also bridged it to the power thats going to the box.
for the "signal in" wire i spliced into the white wire at pin 10 and made sure it was set to 4cyl.
ive tried both the hi and lo voltage positions but still get no movement on the tach.
can anyone give me some insight if im doing something incorrect?
and of course a pic of the truck
XwalkerX is offline   Reply With Quote
Old 01-02-2016, 06:18 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: factory tach with 5.3
I don't know what an l33 is or what ECM/PCM it uses but on my '67 with a stock tach dash & LS1 with the 411 PCM I just hooked the tach wire from the PCM to the tach output post on the back of the tach and changed the PCM resolution from 6 to 3. Seems to work OK....
Here is what lsnova said in another post:
Depends on what year your PCM is, but generally the 2003 and newer will need the pull up resistor. Also you'll have to change the tach resolution from 6 to 3 in the tune to make it read correctly since LS motors use a 4 cylinder signal, otherwise it will read half of what it's running (on a V8 tach). Other than that, just hook up the ignition wire like it was originally and hook the signal wire, the one that went to the coil, to the tach output out of the PCM, generally a white wire at C2 10, but that may depend on year and application.
LockDoc
Leon
Old 01-02-2016, 06:40 PM   #3
XwalkerX
L33 is just the engine code for the HO 5.3L.
Also I'm an idiot and I figured it out. I was running a tach wire to ground when the tach is already grounded in the cluster.
Everything works as it should.
Old 01-02-2016, 08:27 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Would you elaborate as to the actual function of the box? I'm not using a 72 tach, so is the problem an issue of pulse signal?
For me, running an aftermarket electronic tach, a pullup resistor and the regular tach output was all that was needed (running on 4cyl mode). I'm wondering what the box does that a .30c resistor doesn't?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-02-2016, 11:53 PM   #5
foamypirate
foamypirate's Avatar
I would assume it's used to allow a factory tach to operate correctly, though it sounds like changing something in the tune can also allow this.
foamypirate is offline   Reply With Quote
Old 01-03-2016, 04:54 AM   #6
XwalkerX
the box essentially allows you to run factory gauges but yes there is also the route to changing it to an 8cyl output in the tune. i dont have someone readily available to adjust my tune so im ok with buying the box.
also in an aftermarket tach you wouldnt need something like this because you can typically change the tach input to read in 4cyl mode then just add a resistor to beef up the pulse signal strength.
Old 01-03-2016, 06:03 PM   #7
aknovaman
I have used these for years and are half the price. I use them when swapping in a v8 into a chassis that originally came with a v6.
http://www.bakerelectronix.com/products_tsd/
I use them when converting from obd2 to a obd1 PCM in the 96 Impala SS so the dash reads the correct RPM.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 01-03-2016, 09:45 PM   #8
68c10airstream
68c10airstream's Avatar
Terry at lonestar dyno straightened my factory tach issues with my 2001 5.3 ls. I replaced the 5,000 rpm tach, installed the 8,000 rpm tach and sent my 411 pcm to terry. He changed the settings and if i remember correctly he said you can scale the tach signal to be a higher voltage so you don't need a pull-up resistor. He fixed this along with a few other things and worked perfectly upon install. His avatar is "CRITTER".
68c10airstream is offline   Reply With Quote
Old 04-03-2017, 01:41 PM   #9
1972k10shortbed
I have tried to hook my tach up with my 5.3 and also my stock 350 truck. Neither one worked. Ive never hooked one up properly before. Any help would be appreciated.
1972k10shortbed is offline   Reply With Quote
