Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-02-2016, 07:30 PM   #126
hemi43
hemi43's Avatar
Re: Hemi's 70 Blazer build
9 seconds of fun !
https://youtu.be/RJJc1oGZ-Yc
hemi43 is offline   Reply With Quote
Old 01-02-2016, 07:54 PM   #127
IronCanine
I'm trying....
IronCanine's Avatar
Woohoo!!!#brrrr
IronCanine is offline   Reply With Quote
Old 01-02-2016, 08:30 PM   #128
grillzy
Very exciting!
grillzy is offline   Reply With Quote
Old 01-03-2016, 10:11 PM   #129
tjsblazer
tjsblazer's Avatar
Cool. Were you sitting on a milk crate.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 01-04-2016, 04:27 PM   #130
hemi43
hemi43's Avatar
HAHAHA !! No, I bolted the seat in. I've driven cars in the past sitting on milk crates and I know what can happen. I'm older and wiser now !!
Old 01-04-2016, 04:35 PM   #131
crappie66
Very nice
crappie66 is offline   Reply With Quote
Old 01-06-2016, 11:05 PM   #132
hemi43
hemi43's Avatar
Today was paint day. I let the high build sit for almost 40 days before blocking it with 500 dry. I put 2 coats of grey sealer, 3 coats of base and 3 coats of clear and will color sand it hopefully this weekend. Turned out pretty good.
Old 01-07-2016, 01:08 AM   #133
HARDCORECASH
Nice work Hemi43!!! Looks great!!
HARDCORECASH is offline   Reply With Quote
Old 01-08-2016, 05:03 PM   #134
hemi43
hemi43's Avatar
Thank you !!
I buffed the 1/4s today, and must say it's a bit nerve racking putting a D/A on a freshly painted panel. It's been a few years since I cut and buffed, but after a few minutes my heart rate went down and was able to finish without a hitch.
Amazing how well it came up considering I'm using old products on this thing. Believe it or not but the date code on the bottom of the high build urethane primer is 1997 and the clear is 2002. If products are kept in a cool dry place and have been unopened, they should last indefinitely. Some base colors like white don't last too long though.
Old 01-08-2016, 09:02 PM   #135
grillzy
i need some paint lessons from you!
Old 01-08-2016, 10:59 PM   #136
IronCanine
I'm trying....
IronCanine's Avatar
Looks great Dan! You're in the short rows now.
Old 01-12-2016, 12:45 PM   #137
hemi43
hemi43's Avatar
This is the best part of a build, putting new parts on !
I should be painting the rest of the panels but got carried away installing the bling. Putting the 33"on sure changes the look of the truck. Hopefully I'll get the trims rings soon, because they've been on back order for some time.
I was also able to put the Peel&Seal down on the floor. Not sure how much noise this will get rid of considering I'll be driving a tent on wheels.
Old 01-14-2016, 01:36 PM   #138
jaros44sr
jaros44sr's Avatar
Very nice, tires fill up wheel wells nicely, great work so far
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-14-2016, 02:50 PM   #139
tjsblazer
tjsblazer's Avatar
Dan, truck is looking great. Would love to see a full side shot of it to see the tires and stance next time your in the shop with your camera.
Did you buy new bumpers or refinish ?
FYI, I have read a few posts from others who have exhaust straight out the back. They reported getting a lot of suction of fumes back in to the passenger compartment with the top down.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 01-15-2016, 01:17 AM   #140
hemi43
hemi43's Avatar
The exhaust is a big concern. My thinking is if I drive fast enough, the fumes wont reach me !! To be honest, the top wont be taken down very often. I live in Canada !
I'll get a side shot when I pull it out of the booth, but I still need to raise the back about an inch to match the height of the reworked front springs. I think I'm also going to move the rear axle back about 3/4" so that it's a bit more centered in the wheel well.
Old 01-15-2016, 08:12 AM   #141
grillzy
I had a CJ-7 with exhaust out the back and it was a very stinky ride. My 72 has it out the side and is much better. I get more exhaust fumes with the soft top on than off. The tent is noisy! Much nicer with the top off.
Old 01-16-2016, 10:02 AM   #142
hemi43
hemi43's Avatar
Almost done painting. Still have the hood and tailgate to do.
Old 01-18-2016, 11:18 PM   #143
shenk10
shenk10's Avatar
Awesome build. I was wondering who you got all your patch panels through and also for the rear bed half, I'm assuming it was meant for a truck so was the only modification making the holes for the gas tube? Thanks
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 01-24-2016, 08:02 PM   #144
hemi43
hemi43's Avatar
I got everything from Bill's trucks. Best part is that he's 10 minutes away and has everything in stock. The bed floor is for a truck and I had to add the holes for the rear seat as well as the gas tube hole.
Truck is coming along great and I can see light at the end of the tunnel.
I had to machine some lift blocks for the rear to level out the truck after getting the front springs done. I lifted it 1.100" and it's now perfect. This was a good time to move the axle back .625 so that it fits the wheel opening a bit better.
It should ride better now with the longer wheelbase !
Now that it's sitting level, I'll check the U-joint angles and will taper the block if need be, then I'll powdercoat them.
Panels fit pretty good, but I wished I had more of a gap on the cowl sides. I think I'll have to live with it.
Old 01-24-2016, 08:52 PM   #145
IronCanine
I'm trying....
IronCanine's Avatar
Strong work Dan.
Old 01-24-2016, 10:41 PM   #146
hemi43
hemi43's Avatar
Originally Posted by IronCanine View Post
Strong work Dan.
Thanks!! I was looking at your build today to see how well your cowl fit and it looks great. Mine is extremely tight side to side and I won't be able to have the same size gap as the hood. My fenders are bolted on with no shims which is probably one of the reasons, but that's where they need to be in order for them to line up with the doors. I'm crossing my fingers that the hood doesn't give me too many fit issues. I'll find out soon enough.
Old 01-25-2016, 06:44 PM   #147
IronCanine
I'm trying....
IronCanine's Avatar
Our hood gap is obviously the largest of our gaps and thats as tight as we could get it and still clear the cowl on opening. As it was, we still got in the habit of putting a little traction on the hood on opening to ensure no rub. Our gaps were so jacked to begin with, we were pleased with our outcome. We didn't grind any gaps to make them artificially symmetrical (though we talked about it)...just did the best with could with the shapes we had.
Old 01-25-2016, 08:16 PM   #148
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Been following your build from the start. Amazing craftsmenship!
Question - Did you use repro inner fenders? If so, where did you get them?
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 01-26-2016, 03:13 PM   #149
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by hemi43 View Post
Thanks BigJ;
Here's more boring primer pictures.
All original panels like the doors, hood and body were sprayed with Featherfill after the epoxy cured for 3 days. The fenders and tailgate as well as a few other pieces that needed no major blocking were epoxied then Urethane primed wet on wet.
All the priming is now finished, and now I need to wait a month before blocking. This is crucial because urethane needs time to gas off or else it will sink and show sanding scratches down the road. I will however paint the firewall so that I can put the body back on the chassis.
I love your build. One thing that caught my eye was you said you waited 3 days to paint over the epoxy. Epoxy has a cure time that you cant exceed or the top layer will not stick. HOpe that doesnt come back to bite you.
As for the sand marks, thats not necessarily true either. If you use the correct sanding stages the shrinkage you speak of will not happen(or better yet wont be seen)
Cant wait for more updates.
** I posted this before i had reached the end of your thread. That thing came out amazing. Using a 19 year or urethane seems a bit sketchy, but holy hell it came out perfect. Do you have a paint code for that
tank color you used?****
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 01-27-2016, 09:32 AM   #150
hemi43
hemi43's Avatar
Epoxy primer MUST be cured 72hrs before applying Featherfill which is polyester based. The epoxy was sanded before I applied the Featherfill because it was outside it's recoat window.
As far as urethane primer, it will always shrink regardless of how well the substrate is sanded. I agree fine sanding scratches probably wouldn't show up, but why take a chance. If it was a daily driver I was painting, I would sand it the next day.
The paint code for "Tank" is 2014-2015 NGK(Jeep only). Don't paint a Blazer this color because it's already been done !!
