01-02-2016, 07:31 PM | #1 |
weld seams
On Task Force trucks,
Does everybody have the seams crudely installed over their doors inside the cab? A friend mentioned that he wanted to finish the seams like mine, and I never did anything to the seams except scuff and paint them. Did anybody get finished seams with their truck?
http://http://67-72chevytrucks.com/v...d.php?t=489721 Last edited by Coupeguy2001; 01-02-2016 at 08:08 PM. |
01-02-2016, 09:55 PM | #2 |
Re: weld seams
Welded and smoothed mine over the doors but for some strange reason, I wanted to keep the seam line across the back, so I did. Same logic as chopping the top 3" and going to a lot of work to smooth, straighten and KEEP the drip rails. Go figure.
01-02-2016, 11:14 PM | #3 | |
56 - autocross
Re: weld seams
I was thinking about cutting the mismatched seam, realign them, and weld. It would be a lot of work overhead. |
01-03-2016, 12:36 PM | #4 |
Re: weld seams
Like a patch panel. center, left, right tacks, repeat. I won't take all the credit though. My paint cost more than most, but my paint guy went over the inside just like the outside, including dash, so it's all very smooth.
01-03-2016, 01:09 PM | #5 | |
Re: weld seams
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
01-03-2016, 01:12 PM | #6 |
Re: weld seams
i was sooooooo tired of body mods by that time i left the upper cab seams ugly
and... so far no one has noticed
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 01-03-2016 at 01:50 PM. |
01-03-2016, 02:49 PM | #7 |
Re: weld seams
Yeah, realistically unless it is a mind blowing full on custom, leave them. Even on a custom I kinda like things like the welds showing and stuff. It makes the custom work look all that much better like "hey, there's no bondo here" kinda look. Almost like the custom work is original, you know what I mean?
Brian
01-03-2016, 02:56 PM | #8 |
56 - autocross
Re: weld seams
Yeah you might be right (Martinsr) but the inside is just plain ugly. Rob from No Limit mentioned to me that these trucks are just tractors with windows. If you work on them for a while, you really realize how rough they really are. I imagine they were never intended to last 50+ years and to find their way into the custom market. work truck then thrown away. I have even thought of using raptor lining on the inside to cover all the seams. I am not sure that would look good though.
01-03-2016, 03:07 PM | #9 |
Re: weld seams
I have been working on them for years, I remember when I would have wanted to fill them too. But now, after working on late model cars with all their perfection I like the old stuff's character.
Brian
01-03-2016, 05:54 PM | #10 |
Re: weld seams
My painter said he would finish the seams if I tack welded them. Took my time but really glad I did. The ones in the door frames and front of the cab really made a difference. tbrown
tbrown's 56 Cameo Build |
01-03-2016, 09:36 PM | #11 |
56 - autocross
Re: weld seams
Did you tack weld the edge of the metal that overlaps or drill more holes and rosette weld them?
Any pictures? |
01-04-2016, 09:38 PM | #12 |
Re: weld seams
I cut the seams at the door jambs then used a large punch to tuck the edges in then re-welded the seam.
01-05-2016, 11:28 PM | #13 |
Re: weld seams
tack, tack, tack...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
01-05-2016, 11:32 PM | #14 |
56 - autocross
Re: weld seams
01-05-2016, 11:53 PM | #15 |
Re: weld seams
I've really debated doing this on mine and ultimately decided to leave them as is. There's no limit to the mods I COULD do but at some point I've just got to stop on a driver truck. Hopefully a truly nice driver, but still a driver.
I had a friend who filled his seams with plastic filler. Everyone says it'll eventually crack. Has anyone ACTUALLY seen this happen? On a TF truck, I mean.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
01-06-2016, 09:58 AM | #16 |
Re: weld seams
Anyone tried tooling seam sealer? Too much area to cover...? R/Jim
