Rear Differential Fluid Question
Hi, so I have a little bit of a question regarding the rear differential fluid. I just had the rear differential fluid changed about 150 miles ago and I'm having to continue to take it back multiple times because it keeps leaking and they have cleaned and resealed it but no luck. What type of fluid do you guys recommend using? It's a 10 bolt posi 4.10:1 HO52 rear end by what it looks like and I've already check the gear ratios by pushing the vehicle and paying attention to the rear wheel rotation and drive shaft rotation. I am just losing trust with shops because I keep getting half ass work. I already am doing the brakes, oil change, and cosmetic work myself so I'm just going to do all of it.
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Rear Differential Fluid Question
Sounds like they are using the wrong sealant. Here's the right stuff, made specifically for use with gear oil. I'm using Mobil-1 75-W90 full synthetic in my HO52. No leaks.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Yeah, that's what I'm thinking. I've been reading and it looks like 80w90 gear oil is what I should be using in this HO52. So it looks like I'll be picking up some brake cleaner, royal purple, and rtv later this month.
