02-27-2004, 01:53 PM | #1 |
Camaro rear sway bar
I am buying a rear sway bar from 67cst (thanks again Derek) and wanted to know if it will work if I put the 2" lowering blocks on the rear. I'm sure it will work with some more mods, but has anyone done this or know if the blocks will effect the installation
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
02-27-2004, 05:36 PM | #2 |
WHYBYNU when old will do?
I'm not positive, but I would have to say it would, at least I hope so, because I plan on putting 2" lowering blocks and a Camaro Rear Sway bar on my truck too . I'm just going to put the blocks on first to make sure that when you bolt the sway bar on, you have the correct length end links. If I'm wrong, someone please correct me so that we both don't make the same mistake!
-72 Chevy C10 Stepside -2002 Chevy Silverado 2500HD 4x4 -1984 Jeep CJ7 -1995 Polaris XCR600 Custom -2003 Honda 300ex |
02-27-2004, 05:54 PM | #3 |
I to am curious
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
02-27-2004, 08:32 PM | #4 |
You would just need longer end links. Seeing you will probably have to get new ones anyway it should be no big deal.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
02-28-2004, 12:18 AM | #5 |
i have lowering springs in my truck with the camaro bar installed. Both springs and blocks put the top of the housing closer to the frame. I don't think it would make a difference. Lowering the truck would require shorter end links
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
