Old 02-27-2004, 04:06 PM   #1
Inthuwind
Straight jacket required
Inthuwind's Avatar
SCORED a 396 but...need info
I just picked up a rebuilt 396 for 500$$--what mounts can I use to stuff this into a '68 stepside????
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 02-27-2004, 04:17 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
You'll need these and more...
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 02-27-2004, 04:43 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Those mounts bolt directly to the frame. You will need to drill one additional hole in the cross-member but the upper holes are alread there in the frame as is one of the lower holes on the x-member.
This is not as easy as an I6 to a small block swap.
Assuming 2wd, you'll need to consider:
1. Driveshaft shortening. The BB sits the engine back towards firewall somewhat.
2. Along the same lines, you'll need to address column shift linkage or floor shift location as well as clutch linkage.
3. The accessory brackets and exhaust manifolds are completely different than those on a smallblock and expensive to locate.
4. Fan shroud is different.
5. You may need a high hump for your cab as well.
I've done this swap, but I was fortunate enough to have a complete unmolested donor to grab the necessary pieces from.
Here is a pic:
Old 02-27-2004, 04:44 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
another
Old 02-28-2004, 07:09 AM   #5
Javy
Javy's Avatar
Here is a picture of a big block in a 67-72 (427)
Javy is offline   Reply With Quote
Old 02-28-2004, 07:11 AM   #6
Javy
Javy's Avatar
I recommend you search for big block motor mount theads.
Old 02-28-2004, 08:29 AM   #7
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Javy, Nice motor! I guess you have never had a carb backfire through those "firestarter" aircleaners...LOL! Get a hip mount for your fire extinguisher!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 02-28-2004, 09:12 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
As sweet as that hig rise is, you really should get rid of the air filters, they are a seriouse fire hazzard.
Old 02-28-2004, 12:21 PM   #9
Inthuwind
Inthuwind's Avatar
Air cleaners
I agree, those air cleaners are a fire hazard--happened to me in my 10th Anniversary Trans Am. NOT A PRETTY SIGHT!!!!!
