Old 01-07-2016, 12:46 PM   #1
DaHos
DaHos's Avatar
Champion radiator mc369 4 core
Why do they sell these? Fits great side to side but they are too tall!!!!!
Fwiw the 4 core saddles work. Sorta????
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 01-07-2016, 01:11 PM   #2
davepl
davepl's Avatar
Re: Champion radiator mc369 4 core
Any room to work with on the bottom? You don't need much, even just 1/2" to get the top saddles to likely bite enough to clamp down.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-07-2016, 01:17 PM   #3
DaHos
DaHos's Avatar
Even if I shave the rubbers it won't work....the aluminum tank/welds end up rubbing on the metal retainers defeating the need for the rubbers.....
1967 C10 SWB
Old 01-07-2016, 03:28 PM   #4
Freddo
I ran into a similar problem with my 'Spectra' radiator. A suggestion was made to cut a piece of garden hose to use in place of the rubber grommits. I saved my grommits & cut a section of an old bicycle tube, folded it over & set it into the brackets. The radiator still rode high but at least it was held in place. The upper mounts were also high. I put several washers under the upper mounts where it mounts to the frame. The other item affected was the shroud because the radiator was riding higher, I had to make 2 small plates about an 3/4 inch wide by one inch long and put a hole in each end. I mounted the top hole to the frame and bolted the shroud on to the lower hole which allowed the shroud to ride in it's original position. Not a great solution but it was the best I could do.
Freddo is offline   Reply With Quote
Old 01-07-2016, 07:38 PM   #5
DaHos
DaHos's Avatar
This was purchased to correct the same problem I had with my Spectra copper/brass 4 core.........2 different trucks same issue....... And I DO NOT want spacers, just a 4 core that fits !!
1967 C10 SWB
Old 01-07-2016, 07:55 PM   #6
54belair
54belair's Avatar
Man, That's one mistake I didn't make (Ive made many on my build--but at the last minute I decided not to buy one of these)
Is there any interference with the hood? If its just too tall and doesn't hit anything a new set of brackets could be fabbed. (something else to do!!)
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 01-07-2016, 09:34 PM   #7
jeh
jeh's Avatar
I have a Champion in my truck and it fit pretty decent. I did shave just a little off the rubber pieces but it was closer than yours looks to be. I don't remember the part# on mine
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
